LT 80 Wont stay running
My son has nand LT 80 that I been working on the problem is it wont stay running been trying to adjust the carb but no luck. It will stay running if I hold the chock on, also even when its been running for a while I stll have to use the Choke to start it after it dies. Almost sound like its sucking air from somewhere and holding the choke on compensates. What's the deal?
Thanks
Thanks
The person who made the suggestion of the crank seals did so partially because i had taken the barrel and piston to him for a rebore due to scratches at the front and back, the engine has a load rattle but he considered the damage he could see was not significant enough to cause such a noise, when i told him about the engine being run for some considerable time without oil in the petrol and also the starting and tickover problem he considered the noise was likely to be the bottom end or crank bearings and the running problem due to the seals.
Does anyone have any views on this as i am being told the engine needs a complete rebuild, any experiance out there on usual problems after running without oil ?
Many thanks
Many thanks
whitty
67
02-24-2021 02:52 PM
