Heard the belt squeel on the eton Viper 90r
Old 11-09-2009 | 12:45 PM
rjdad's Avatar
Default Heard the belt squeel on the eton Viper 90r
My son was running through some deep water and I did hear the belt squeel. My question is what do I need to check/do in order to prevent this from happening again...besides the obvious (don't go through deep water). Thanks in advance.
Old 11-14-2009 | 04:47 PM
twister500's Avatar
What year I have an 07 90r 4 stroke for my daughter and it's chain drive not belt.
Old 11-18-2009 | 01:43 PM
rjdad's Avatar
twister500,
Sorry for the late response...but my son's is a 06 (the last year they made the 2 stroke i think) and the squeel was from the cvt belt? I was wondering is there any way that I can do for added security rather than the obvious of not running in water.
Old 11-28-2009 | 08:42 PM
beltburner's Avatar
not much you can do to seal up the clutch since it will heat up but if it only happens once in a while the belt should be fine as long as you let it dry out before running it more. also make sure that the filter under the black plastic housing is oiled like the air filter.
Old 12-02-2009 | 09:06 AM
rjdad's Avatar
Beltburner,
I'm not sure I understand you...what other filter? Thanks in advance
Old 12-02-2009 | 06:54 PM
rapple's Avatar
There's a small often overlooked filter on the front of the transmission housing. I'd bet yours is plenty dirty (and wet).
Take it off and if you have a compressor, blow some air in there to dry things out and you should be fine.
Old 12-03-2009 | 04:27 PM
rjdad's Avatar
rapple,
Since this weekend is suppose to be a bad day for us here in Central Texas I will have time to look at and clean this filter. Thanks for your help!!!
Old 12-03-2009 | 06:28 PM
rapple's Avatar
Our Polaris is in storage at the moment, so I don't have access to it to look, but if memory serves, it's behind a plastic shroud. The parts fiche @ BikeBandit.com should shed some light on it.
Jeff Roper
02-01-2022 11:48 AM
flyin-lowe
12-01-2017 03:18 AM
badgerboy1
09-26-2017 06:11 PM
buddieboy
12-09-2016 05:50 PM
Scooter's Shop
10-09-2015 02:09 PM
Quick Reply: Heard the belt squeel on the eton Viper 90r
