LT80 stall speed
Old 09-22-2013, 04:19 PM
Brian Adwell's Avatar
Default LT80 stall speed
I'm needing a higher stall speed before clutch engagement.It had a perfect stall speed until I removed my PVL ignition now I can't seem to get that stall back?I am already running with lightened rear shoes and 3 factory front rollers what else do I need to try?
Old 09-23-2013, 07:28 AM
LT80's Avatar
LT80 Expert
You are not going to get the same stall speed with a stock ignition.
Old 09-23-2013, 07:50 PM
Anything I can do to help get some stall back?
Old 09-23-2013, 08:22 PM
LT80's Avatar
LT80 Expert
You can lighten the flywheel but it'll never jump like w/PVL.
Don't want to fix it?
Old 09-23-2013, 09:30 PM
Yea,I'm gonna fix it for sure knowing it makes that much of a difference just don't have the $150 for a new stator from Penton.Just thought I could tune some other things to make up the loss on bottom because its a night/day difference without it on.
Which sprocket/chain combo is lower geared for bottom-end?
11/22 ---520 chain
12/26 ---40 chain
Old 09-24-2013, 07:30 AM
LT80's Avatar
LT80 Expert
11/22 ---520 chain
12/26 ---40 chain
Same (or close) ratio.
Pehter
09-04-2016 08:22 PM
QuadRiders
10-22-2015 04:13 PM
ReconBayou
09-23-2015 02:41 PM
merryman
09-19-2015 03:15 AM
Jaymc
09-11-2015 07:45 AM
Quick Reply: LT80 stall speed
