How do I remove the recoil reel on 2003 Polaris TB
Old Oct 31, 2011 | 09:38 PM
RB6908's Avatar
Default How do I remove the recoil reel on 2003 Polaris TB
Hi,
I am trying to replace the starter on my wife's 250 Polaris TB however, I cannot seem to get the stupid reel to come off. Is there a special method/technique for doing this? This thing is driving me nuts, I know it comes off counter clockwise but it's not working for me. Please help!
Thanks.
Old Oct 31, 2011 | 10:25 PM
RB6908's Avatar
I need to take it off anyway because I need to replace the rope. So I will need to take the black cover off as well. However, in doing this, will I lose my oil? Is there any certain type of silicone that needs to go back on it?
Thank you so much for your reply!
Old Oct 31, 2011 | 10:32 PM
Remove the bolts around the main recoil cover,leave the 4 bolts around the black reel cover on. Some times the long bottom bolt hangs up(if you can't remove it),just unscrew it and you can pull it partially out and wiggle the cover out. You are talking about replacing the electric starter?? Or are you talking about repairing the recoil? OPT
Old Oct 31, 2011 | 10:37 PM
RB6908's Avatar
I have already pulled the main clutch assembly off, the transmission pulley and belt, the black cover, 2 bolts that hold the back of the starter on, and the power wire to the starter. Basically the starter went out and the rope broke last week. So I need to do both.
Old Oct 31, 2011 | 10:50 PM
Just remove the main cover first to expose the 2 remaining starter bolts and you can replace the electric starter. The recoil housing can be worked on the bench(If the spring ISN'T broken,just rewind a new rope through the cover onto the reel and turn the black cover until the rope bottoms out,then pre wind the reel and cover about 5 turns,then replace the 4 cover bolts! If the spring is broken,reel will have to be removed. You have to lock the rear part of the recoil in a vice WITHOUT damaging the ratchet assy and loosen recoil reel counter clockwise by hand. Sometimes its hard to break loose! Manual is recommended if you have to repair the recoil OR let a shop do it as there are several parts that can be broken if you're not careful!! OPT
Old Oct 31, 2011 | 11:37 PM
RB6908's Avatar
Man, I really appreciate your help! I am sure my "wifey poo" will be just as excited when I am able to get her wheeler fixed.
One more thing, it does not appear to have the original air box on it, is this a problem?
Thanks again!
Old Oct 31, 2011 | 11:39 PM
RB6908's Avatar
Is it possible that the starter could be stuck in the housing after all the bolts have been removed? I am working on this wheeler as we speak.
Old Nov 1, 2011 | 06:50 AM
Find a used air box off a wrecked machine OR use an oiled foam pod filter in worst case scenario! The stock air box has a foam prefilter and a replaceable paper element filter,OR some have used a cleanable main filter along with the foam pre filter. Important to use a good filter on the 2-strokes!
On the starter section ,the bendix comes out WITH the starter from the backside and goes back in as an assembly,sometimes they are a little hard to pivot out if you still have the rear starter bracket in place or just stuck at the starter gasket,just tap around it and it should pull out! OPT
Old Nov 15, 2015 | 05:08 AM
aSCsmalls's Avatar
How can we remove only the reel from the post? WD40 doesn't seem to loosen it.
Old Nov 15, 2015 | 08:37 AM
If the spring or reel is broken and has to be removed,you have to carefully lock the guide assembly in a vice and turn the reel counterclockwise. Very easy to break this guide if it's not clamped down right. Remove the spring and ratchet first. The reel is screwed on pretty tight. Item#28 is the part you have to lock down.Dirt Cheap Yamaha, Polaris, Suzuki & Kawasaki OEM Parts & Accessories – Cycle Parts Warehouse
Jmuddin284
Jan 19, 2026 07:16 AM
Coryco
Jul 6, 2015 07:30 PM
jettman
Jul 6, 2015 12:16 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
Shifts
Jul 3, 2015 07:59 AM
