Register and Sticker for Quad
Old Dec 27, 2003 | 10:32 AM
RookieRacer's Avatar
Default Register and Sticker for Quad
I am going to NH tomorrow to ride. I need a Sticker so my scram doesnt get inpounded, I live in Ma. Do i need to register it in ma. or nh? and where the hell do i get this. Hopefully someone in Ma. will read this and help me out. Maybe someone will know where to go for me to get registered so i dont have to go thru problems tomorrow. Thanks guys. OH ONE MORE THING!! I want a light when i put it in reverse for in the dark. Is this possible and has anyone seen it or seen it done. I ride alot at night also. I want to see for when i have to back up. HELP !
Old Dec 27, 2003 | 11:55 AM
modquad's Avatar
You can probably check with a local dealer. Some neighboring states often times have agreements on registrations. A local licensing office should also have the info...although the government office would probably be closed on the weekend.
As for a compact "back-up" light. Moose Off-road has a series of utility lights, and mounting one of those in a protected manner would work nice.
Old Dec 27, 2003 | 12:04 PM
Northstar2's Avatar
I'm pretty sure that a mass reg is still good in NH. I would register it in Mass so you can still ride it there, too. They just changed it in Maine, so I have to buy a Maine reg if I want to go to Maine, and they have to buy a NH reg to ride here. So much for reciprocity. Why is my car registration good in Maine but not my atv? Money, thats why. money grubbing politicians. Anyway, Mass will probably change soon, but dont believe its happened yet.
As far as the reverse light, I was told on the sportsman there is a purple and white wire with a female connector on it hanging loose under the hood. (I havent tried it yet) this gets power when the reverse indicator gets lit. I dont know what your machine has for a dash, but if it has any kind of indicator light there is a power wire somewhere that will get hot. It might not be purple/white, but a few minutes with a test light should find it. I plan on putting an in-line fuse or a circuit breaker in when I do mine, because the light I have is a 55 watt fog light, and the machines wiring is probably not that stout. I think the wiring would get too hot with that much current draw if you left it in reverse too long. Of course, you could put it on a toggle switch easy enough, but that would be real easy to leave on and forget about.
Old Dec 27, 2003 | 12:06 PM
Northstar2's Avatar
there is a dealer at the state line that would definitely know the answer. dont have their number right in front of me, but its called Plaistow Power Sports. they are in the book or you can track the number down from the Yamaha website under dealer search.
Old Dec 27, 2003 | 04:43 PM
scrambler420's Avatar
where in mass are you,and where in nh do you plan on going?as for the sticker,you cant use a mass registration in nh,it will cost you $73 for a nh sticker and if you get it now its only good till june,nh registration runs from june to june its not good for the whole year..so say you get the sticker in may then it would only be good for a month,kinda stupid if u ask me but thats where they make their money..
Old Dec 27, 2003 | 04:58 PM
DaveMaxx's Avatar
Make sure you use a 12 volt RELAY!!!
Any auto parts store will have them. hook the relay to the battery with a fused wire(always hot) and to a good ground. You will have to check your wire you will be using to trip the relay on and off, I think it is open circuit when light is off but provides a ground when in reverse. The relay can be set in energize with a ground trip or with a voltage trip. The relay will pull the 5 amps off the battery for the light instead of the factory wire. A relay will pull less than half an amp from the factory wire to trip the relay.
Hope this helps!
Old Dec 27, 2003 | 05:37 PM
Northstar2's Avatar
June to June isn't a whole year?
I didnt realize NH had changed and was no longer reciprocal with Mass. Doesnt surprise me though. Anytime the bastards see someone with money to spend (such as recreation) they stick their fingers into it.
Old Dec 27, 2003 | 05:57 PM
yeah if you register in june then its good for a whole year but if you register now its only good for 5 months,i think it should be good for a year from the date you get it..
Chillibean
1) Engine problems..
Sep 5, 2020 04:02 AM
Frisky2050
Apr 9, 2020 11:19 AM
greg74
Sep 10, 2019 03:03 PM
RickyMac
Mar 5, 2016 07:27 AM
Nondem
Where to Ride
Jul 23, 2015 07:38 PM
