500 sportsman, wont go in gear
Old Oct 14, 2006 | 01:24 PM
yodog's Avatar
Default 500 sportsman, wont go in gear
Dont know much about polaris~ 2002 500 sportsman
Wont change gears, suck in N
Will it start in gear?
Should I be able to change gears when not running?
checked linkage to tran.case, tryed holding brake???
Old Oct 14, 2006 | 06:03 PM
JP466's Avatar
Mine did this and it was the motor mount being lose causing the linkage and tranny to bind. It could also be a bent sift fork. It should shift when not running and yes they can start in gear.
Old Oct 14, 2006 | 06:26 PM
yodog's Avatar
Thanks for the reply, I can't get the big pulley off the belt rides on. I'm scared I'm going to brake it or bend it.
I feel it shouldn't be that hard to get off!
I'm looking at the shifter fork being in a bind or bent??? If I can ever get case out of frame to break down!!
Old Oct 14, 2006 | 11:01 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
you should be able to get your belt off the secondary (b.pulley) then the one bolt holds the clutch on a spline to the shaft. pretty much just slides off. you may have to spray some bp blaster to break some rust or corr. maybe w/ a rubber hammer tap on the back side to slide it off.
Old Oct 15, 2006 | 01:20 AM
GJRonK's Avatar
My '04 stuck in reverse last week. I disconnected one linkage pin in the middle so I could wiggle the shifter box linkage better. That worked. No problem since. Something in the shifter box must have been mis-aligned.
GJRonK
Old Oct 15, 2006 | 02:11 PM
yodog's Avatar
The other week , I took the belt off and bolt out of pulley, tried rubber hammer and a bar to put pressure on it. I couldn't get it to move? So , I got this big??fly wheel Remover? tried it and while tapping it with a rubber hammer and felt like I was going to damage it!
I will go buy some Pb blaster and put wheeler on its side, spray it and let it set over night.
Thanks
Old Oct 18, 2006 | 11:59 PM
yodog's Avatar
Thanks, I let that bp blaster set on there few days, and put that puller on it , it came right off!!!
The tran looks simple to remove but it say, " make sure I unhook switches before dissemble and resemble" anyone know, what switches they are talking about"?
Old Oct 19, 2006 | 08:09 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
maybe a couple or wire harnesses from the gear selector sensor should be able to see them i would think unsure though w/out looking.
Jmuddin284
Jan 19, 2026 07:16 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
coolguy420
Jul 10, 2015 01:17 AM
sara durrant
Jul 6, 2015 05:32 PM
Jkfx400P
Sport Quads
Jul 5, 2015 10:33 PM
