know anything about clutches??
i know what you mean and the belt does ride right where your describing it.. when i take the cover off its not like the belt is tight i can still move itaround but once its at idol without gasing it the second i put it into gear it stalls
it didnt shread competly but there were rips on the back and a bunch of the teeth came off.. but it was also the stock belt from 02 and its been submerged many times and i've put alot of stress on it going through mud, up hills, towing and the constant heating and cooling of it from mudding
#15
doyou have it idled up high enough. usually it will creep a bit b4 it would stall. im surprised that it doent move the secondary clutch while in neutral.
cdstang
Aug 31, 2015 07:52 AM
