Help!!What is my problem?
Old Aug 7, 2007 | 01:47 AM
coachs's Avatar
Default Help!!What is my problem?
My quad starts fine will idle but after a few minutes it sounds and acts like you cut the air off and it dies. What does everyone on think? blown motor? or
Thanks
Old Aug 7, 2007 | 01:54 AM
zsebi's Avatar
Blown motor? No, that would not start or run... What kind of ATV you got?
check the basics, choke operation, fuel ON? How old is the gas in the tank? has it been sitting for ever? give us more info
Old Aug 7, 2007 | 07:35 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
what does it do when it shuts off. are you checking fire, checking to make sure its not running out of gas? give more details if you can. and no its not any major problem w/ the engine or hes right and it wouldnt even start.
Old Aug 7, 2007 | 01:40 PM
coachs's Avatar
It is a 94 300 4x4 it has sit for a while but I have clean tank/carb. took the plugs out of muffler. When it gets warm it shut down like the air was cut off. Thanks
Old Aug 7, 2007 | 01:44 PM
scootergptx's Avatar
Supersock
Hired Gun!
I'll guess that it won't restart until it has cooled down too.
Sounds like you need to check the compression.
Old Aug 7, 2007 | 04:50 PM
bschreib's Avatar
I have a 99 Scrambler 500 that sounds like a sililiar issue. It will run great for 5 - 10 minutes and then it starts to cough and choke. Won't restart for at least an hour after that. It is getting fuel and I did just clean the carb out.
My guess is electrical. Thoughts???
Old Aug 7, 2007 | 05:12 PM
samk's Avatar
As Stendori said above, make sure you still have spark. The easiest way to check is get a known good (spare) plug. Run the bike until it acts up, pull the plug wire and connect it to the spare plug. Lay the plug against the engine and hit the starter button. If you get spark,,, chances are it's not electrical. Just to be certain that it's not the plug,,, you could throw the spare in once it cools off.
Old Aug 7, 2007 | 05:39 PM
cataway's Avatar
i'm going to ask you to try some thing . pull the gas line hose off the the carb and and run your gas in to a seperet contener ,does the flow change or stop ? if it does remove the gas cap ,does that help the flow of gas ?
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
