plow springs not working well
Well I can't complain seeing on how I got a brand new super winch, a used in great condition Moose plow all for 90 bucks.
Replaced the starter in the sportsman, installed the winch, plow and all the hardware and I am ready to push snow.
But, the springs on the plow are rusted and weak and the plow blade keeps flopping down to much when it hits a slight obstruction.
I already tried the rachet strap idea to hold it with no real luck. I am not about to run out and buy new springs right now.
Anyone have any other fixes for this problem that has worked for them?
thanks for any help.
I have had similar problems with my glacier II plow. I just got a set of new springs today. They were on back order for 2 months! Well now I know why. My new springs are twice the size of the old ones. Maybe polaris is finally going to beef up their plow system. I have a gravel drive way also and the old springs were way to weak. I tried the new ones today and they are great. My advice would be to find a heavier spring set at your local hardware maybe. If the springs are to weak they will just be trashed in a days plowing imo.
so I came up with an idea. I went to the cheapo and they didn't have any springs that would work. So instead of ordering online and blah blah I bought two 12 inch lenght of chain with 750 pounds break strenght. I also bought 4 carabeeners <--(sp) one for each end of the chains, and I connected the chains in place of the springs. when the plow is all the way on the ground, there is a couple inches of play but when it meets resistance, the plow can still move until the chains stop it. It works well, so well that now the plow really grabs!!
<div class="FTQUOTE"><begin quote>Originally posted by: jumbofrank
Your "magic biners" (please pardon the bad pun) should be in the redneck fixes thread. It's a good one. If you found springs that were too short you could clip them on too.</end quote></div>
I did think of that, but I was afraid that the spring would wiggle apart from each other and the springs I could find only had a stretch strength of like 40 pounds.
I need something stronger as my driveway is frozen dirt, lots of hang ups!
