What tires are OK for the sportsman 500 HO?
Hi all
Looking to upgrade my stock tires on my 2006 sportsman 500 HO.
I hate to dive into it blind, look for some insight.
Mainly worried about the machine not being stout enough for more aggressive tires and clearance.
I don't want to put something on there that will damage the machine.
Also, please don't slap me in the back of the head, but is there a good mud tire out there that won't totally destroy my yard?
TLC just said it. If your wanting somthing that is turf friendly and yet decent traction in the mud you need to stick to a less aggressive lug pattern. Example: my popo has XL. mudlites and I chew the **** out of the yard just putting along. Yesterday my brother took his honda out with a brand new set of AT. bear claws and did surprising well in the mud without doing alot of damage to the terrain. Now as far as size goes, an inch plus should prove no challenge to your machine, yet I'd look into a clutch kit if your wanting to go big!. Tire weight can also be a factor in the performance realm. So many choices out there!
Jethrob, if you go with wider tires you will need to create clearance for the tie rod ends in the front. I ended up having 3/8" longer wheel studs pressed in and put a hardened 3/8x24 nut with a hardened washer between the hub and tire rim. It doesn't rub anymore. I ended up with Mudlite XTRs 26x9-12 and 26x11-12. They've performed flawlessly so far. I've had them in thick mud, thin mud, headlight deep waterholes, rocks, hard pack, every kind of snow, etc. They are an excellent tire. I was able to go up a 30 degree slope with 9" of wet snow in 2wd. Dug right down to hard pack. More difficult to powerslide though.
thanks for the input
I didn't realize even the less aggressive mud tires tear up the yard.
I do a lot of putting around the yard with the kids on the wheeler, and need it to move boats around non-graveled areas of the yard without tearing stuff up.
Third before mudding we ride around on the roads. I often ride 10 miles @ 52 MPH or so to get to some trails so the vibrations would not be cool.
Occasionally when I get the opptunity to hit the trails with the guys is mainly when I'm wanting more aggressive. Got stuck a couple of times this last ride, most of them were fairly ridiculous holes but some of the other wheelers made it.
After some thought and consideration I'm now leaning towards maybe buying some tire chains, and just popping those on for the occasional mudding.
Chains will make a 2wd truck (or car, yes we have done it) flat out eat the mud. Have seen a 2wd caprice fly by stuck 4WDS because of tire chains.
I agree with ftwflh. Don't use the chains. You can tear up a lot of things on your ATV if a cross link on the chains break while spinning in the mud ($$$$). There are a lot of tires that are better than stock for the mud that will run the 10 miles you are talking about with very little vibration, but the thing that is the hard part is your yard. I cant advise you there because my 08 Sportsman 500 HO would tear up the yard when I had the stock tires on it. I like the MAXXIS BIG HORN 2.0 for where I ride. (trails, mud/water) and the yearly trip to WV. (Hatfield-McCoy) about 2 1/2hrs from home.
