04 500ho misfire, puzzler please help!
Old Nov 14, 2011 | 07:27 AM
Quite a difference! Early models had the pulling power in the hubs(coil,armature plate,roll cage assembly, and four bearings in each hub) Centralized awd drive systems were contained in the front gear case. OPT
Old Nov 14, 2011 | 09:01 PM
curlytop's Avatar
Mines an early model then. Build date is 5/13/03
Old Apr 20, 2014 | 08:15 AM
Badboybob's Avatar
Default 2004 Polaris 500 HO misfires
My Polaris 500 misfires at low throttle but seems to run fine at high throttle. I don't want to drive fast all the time. At low throttle it misfires and dies. I replaced the plug, new air filter and cleaned out the carb but did not replace any carb parts. Any suggestions?
Old Apr 20, 2014 | 08:48 AM
Make sure you have only 1/8" slack at the throttle lever or it's possible the etc contacts can touch causing problems. Adjuster is under the rubber sleeve on the throttle cable.One of the things most people overlook.Plus just my on this one. Any time I removed a carb,it got rebuilt. Not worth the trouble of having to go back in for any missed spots or worn parts.Carb may or may not be the source of your miss,but you can at least you can rule the carb out when you rebuild it.Plus you can pull the fuel line from the carb and crank the engine over.Should have a steady stream of fuel from the line. This is to rule out any fuel supply problem from the pump,stopped up fuel filter. If none of this helps,then could be an electrical problem and this is where a manual would come in. Has a section on electrical miss along with general checkouts.
Worth the 5 bucks if you don't have one already.2004 Polaris Sportsman 500 Service Manual PDF Downloadhttp://www.ebay.com/itm/Polaris-Sportsman-500-2003-2004-2005-Carb-Carburetor-Kit-/261420203486?pt=Motors_ATV_Parts_Accessories&hash=item3cdddbbdde&vxp=mtr
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
pro94lt
Aug 20, 2015 10:02 AM
WilliamBos
Jun 13, 2015 08:51 PM
Falcon150
May 25, 2015 05:36 AM
Punisher
Jun 4, 2002 08:29 PM
