2010-2013 sportsman 500 recoil
Old 02-12-2014, 04:19 PM
JCDEYO25's Avatar
I've heard of some guys putting a little silicone where the pull cord contacts the housing to eliminate any water from entering but you can break it free if you need...
John
Old 02-13-2014, 11:51 AM
TLC's Avatar
TLC
TLC is offline
Originally Posted by WilliamBos
Thanks. Has anyone ever had an issue with getting water inside the recoil? Under normal riding conditions?
I took my recoil off once and there was so much water in it that minnows were swimming inside of it.
The water ruined my Bendix drive and caused my pulse coil to get dirty and act up.
I was lucky the $300 Stator survived.
Now I do the silicon trick with the pull rope handle. (Like mentioned above)
Pull your pull rope out and look at it. If the rope is wet and dirty that means water has worked its way inside at some point.
The recoil is so low on the Atv that it does not take deep water to submerge it.
You right riding boot or a tree branch can easily knock the pull rope handle off position without you noticing before you do that creek crossing.
Jmuddin284
06-28-2017 04:59 PM
79hugger
08-30-2015 02:21 PM
dwhipper61
08-27-2015 11:01 AM
WesTech
11
08-11-2015 07:55 AM
Desimation2k8
07-17-2015 12:37 AM
Quick Reply: 2010-2013 sportsman 500 recoil
