My Sportsman 400 won't idle... help!
I just bought a '03 Sportsman 400. I haven't ridden it much, less then 10 hours. I went out today and everytime I left off the throttle it dies. I tried adjusting the idle but no good. If you just touch the throttle it idles fine. This first 1/16 of an inch seems to be the problem. If I go past this and turn the idle up, the motor revs right up. Below this the idle screw does nothing. Any ideas?
Sounds like the E.T.C. switch has to much slack in it! when the machine is turned off check how far you can move the thumb throttle before you can feel it pulling the throttle cable it should have no more than 1/4 inch of free play in it.If you have to much freeplay this is probaly causing your problem,but dont worry it is very easy to adjust. [img]i/expressions/face-icon-small-happy.gif[/img]
First off did you check and see if there was freeplay in the thumb throttle,and if so how much, if it is more than 1/4 inch try this trick before you do any ajusting crank the A.T.V. up and let it warm up after it has warmed up sit on it and turn the handle bars from left to right slowly and see if this causes the idle of your machine to change in any way.If it does change this maybe a sign that the throttle cable is routed wrong and possible binding somehow,if not then I will tell you how to adjust the E.T.C switch just want to make sure that the cable is not binding before you start adjusting on it.
About six inches down the throttle cable from the throttle assembly, you will see a fat area in the cable covered by rubber sleeves. Pull these rubber sleeves away. There will be a threaded adjustment with a lock nut. Loosen the lock nut and thread the two pieces out just a little bit. Do this just enough to keep it running. Do not adjust it so far that it will raise the idle.
throttle
chingchangchong
08-07-2022 11:36 AM
slowgsxr97
09-08-2015 07:33 PM
cdstang
08-31-2015 07:52 AM
