1998 scrambler shifter micro switch
Both 1998 400 and 500 scramblers - Jumper the red/white to the grey/white wire at the gear selector switch and the unit will "Think" its in forward at ALL times. Friendly reminder- reverse limiter will no longer function so it will go very fast in reverse after you do this.
Unplug it and jumper the "Harness" side, not the switch side and you should be good to go. Switch is in the shifter assembly, just follow the wires to the harness.
Pic for reference
https://www.ebay.com/itm/1999-Polari...1:pf:0&vxp=mtr
Pic for reference
bigpollyboy
09-15-2016 08:49 PM
