2-Stroke = Lots of Oil around Header?
Old Sep 25, 2005 | 11:32 PM
z3us's Avatar
Default 2-Stroke = Lots of Oil around Header?
I Just got a Suzuki LT250R, New rebuild about 1.5 hrs on the motor. I mixed the oil/fuel @ 32:1 With a Ratio rite so its very close. But Oil is on the pipe, little spots are on the fenders, and a lot is around the exhaust manifold. Is this norm? I am new to this hobby and it dont seen right? Looks as if the manifold is sealed good. ??????
Old Sep 25, 2005 | 11:42 PM
NEWDUCK's Avatar
You have an exhaust leak. When you first start up your quad you should be able to see where it is leaking from. At least that his how i find exhaust leaks on my sled.
Old Sep 26, 2005 | 06:04 PM
sam250's Avatar
Take the pipe off, fill the groove that it slides into with orange RTV and put the pipe back on.
Old Sep 26, 2005 | 09:57 PM
z3us's Avatar
Sweet, Thank you guys for the help!
Old Sep 26, 2005 | 10:36 PM
yamaharaptor350's Avatar
i have a small part where there is air comin out by my silencer and i was wondering if some high temp silacone would work to seal that??? has anyone ever tried that???
Old Sep 27, 2005 | 04:17 PM
Dante7's Avatar
Yeah just run a small bead of silicone around to seal it up just try not to get any down into the pipes so you don't restrict flow.. I have done the silicone on almost every bike i own it works alot better then those stock rubber things they use..
Old Sep 27, 2005 | 05:12 PM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
I use the orange silicone for that and it works great.
Old Sep 27, 2005 | 08:26 PM
k, thanx alot guys
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
dannytas
Sep 26, 2017 06:31 PM
EIF
Apr 20, 2017 07:15 PM
wrencher82
Sep 28, 2015 10:02 PM
wrencher82
Sep 24, 2015 03:39 PM
