KQ 700 cylinder..regular or Nikasil
Old Feb 4, 2007 | 03:39 PM
Kahnman's Avatar
Default KQ 700 cylinder..regular or Nikasil
Is the 2005 knig quad cylinder a nikasil or regular steel cylinder. The cylinder and piston scorched on one side from low oil at idle after hard running. So, I ned to put a new piston and rings. Can I bore it and reassemble or will I have to re-nik the cylinder
Old Feb 4, 2007 | 09:45 PM
Kahnman's Avatar
As I have looked over the internet for anyone that sells an aftermarket overbored piston for the 700 king quad, I have found NONE. Unless anyone here has a suggestion, the only options will be to either repurchase a new cylinder aned stock piston, or get it resleeved by LASleeve and a new piston. ANy suggestions?
Old Feb 5, 2007 | 01:58 AM
Topgun1's Avatar
CP Pistons makes a big bore piston for the 700 King Quad. You can buy the complete kit through Millenium. They take your stock cylinder and bore and replate it for the oversize piston. Also includes the necessary gaskets, piston, and rings. The price is about $595 if memory serves me. That is complete with you sending them your cylinder. (+shipping)
You could probably get your stock cylinder replated if you wanted to go that route. I think it is about $200. Millenium can do that also. Never heard of anyone boring and sleeving the 700. You'd have to get special rings since the stockers are made for the plated cylinder so that doesn't sound like a possibility.
Old Feb 5, 2007 | 01:57 PM
Kahnman's Avatar
I found Millenium before I saw tis post. My dealer is going to send the whole thing to them and they guarantee a perfect, or better than OEM fit and finish with a lifetime warranty!!Will save me about $200 dollars over a new cylinder. Thanks.
BTW, I don't want the big bore because I don't really need it. I figure 700cc's is enough, plus I dont want to spend the money.
Old Mar 29, 2013 | 08:05 AM
emarti96's Avatar
Default millenium work on cylinder
you got a link to millenium, or any contact info? tks. I have same prob w/ my king quad. just want OEM cyl replated, or whatever they do.
Old Mar 29, 2013 | 08:21 AM
LT80's Avatar
LT80 Expert
I'd take your cylinder to a shop that does boring and get a hands on opinion..
I think it's nikasiled and can be cleaned up w/acid.
Then just stick a piston in it.
What did your dealer service dept say? (hint) LOL
HIGHOCTANE
Dec 6, 2008 08:59 PM
ERBEDS650
Mar 4, 2008 12:25 AM
Hightower
Jan 8, 2006 10:57 AM
ERBEDS650
Dec 22, 2005 09:40 PM
Veeshman
Jun 20, 2000 09:35 AM
