ltz50 quad no power
Old Aug 8, 2007 | 04:28 PM
  #111
KINGQUAD450's Avatar
Default ltz50 quad no power
you still won't see any oil the belt runs in the same spot
Old Aug 8, 2007 | 04:36 PM
  #112
edc7002's Avatar
kool,
Listen, any advice you guys can give me from now till 8:30pm will be great...
Old Aug 9, 2007 | 03:06 AM
  #113
edc7002's Avatar
Removing Clutch rollers with pictures [img]i/expressions/camera.gif[/img] [img]i/expressions/face-icon-small-smile.gif[/img]
#1 get everything ready
#2 remove outter case, "5 screws"shake loose
#3 Pull the belt out of the way take out clutch case
>>>back side of clutch>>>
Old Aug 9, 2007 | 03:28 AM
  #114
edc7002's Avatar
remove rear clutch plate six rollers clear as day
Sorry bad pic, but remove three rollers and evenly space the three remaining rollers
follow all steps in reverse
Old Aug 9, 2007 | 03:42 AM
  #115
edc7002's Avatar
Open a cold 1 you're almost done.
use rubber hammer too firmly knock outter case back in place before screwing it tight "also when removing this casing you can remove the pull start first it will help when shaking loose this outter case
"Your done!!!" quad back in the garage...This job should take no more than 1hour [img]i/expressions/clock.gif[/img] .. Well worth the torque
For those of you who knew what the hell you were doing this is how you explain something...... Roller removal gift [img]i/expressions/present.gif[/img] wrap!!!!!!!!!!
Old Aug 9, 2007 | 04:04 AM
  #116
tlronny's Avatar
Great post - but how will this exactly affect the performance of the quad please and are there any side effects ?
Old Aug 9, 2007 | 08:02 AM
  #117
Nice pictures I would have given you some picture but I never got the camera to work with this new computer. Just a couple of questions for you.
1 Did you take all the plastic off for this job or did you have it off for something else?
2 Did you remove the clutch spacer why you was in there?
Old Aug 9, 2007 | 08:44 AM
  #118
edc7002's Avatar
tlronny,
High end power is the same the cdi box is still going to limit the revs.. at the same point but i'll see this weekend when the baby rides it..
But low end torque wow.. I tried to hold the bike back while giving it full throttle; and she pulls!!!
side effects, only that the bike will be more fun to ride [img]i/expressions/face-icon-small-smile.gif[/img]
KINGQUAD450,
1) Yea i took off all the plastic for this job only 6 screws and 4 clips the body comes off in 1 piece...
2) The dealer charged me $98 bucks to remove that spacer ****, when i first bought the bike. Thats why i didn't know what to look for.. If i would have known this was so easy i would have done it myself from the begining. But i still have the spacer i can post a picture of it so anyone doing this job can remove the spacer at the same time....
Old Aug 9, 2007 | 06:03 PM
  #119
DSengineer's Avatar
Has been here a long time!
Really no need to remove ALL of the plastic. Just take off the left side cover and unbolt the footpeg.
Old Aug 10, 2007 | 01:18 AM
  #120
tlronny's Avatar
Why are they there in the first place then if torque is so much better if the weight is halved ?
