ltz50 quad no power
Old Jan 16, 2008 | 02:23 PM
  #531
AIRMOBILE101's Avatar
Default ltz50 quad no power
Do make sure you check the rollers for wear. It doesnt take long for them to start re-shaping themselves.
Old Jan 16, 2008 | 02:32 PM
  #532
I noticed Huntingfromaquad put the 2-stroke against the 4-stroke, is there anyone else on this thread that can do the same comparison?
Old Jan 16, 2008 | 05:48 PM
  #533
chadthayer1982's Avatar
[img]i/expressions/face-icon-small-happy.gif[/img] thanks for the help guys! maybe its just me. i just didn't notice the noise before i removed the spacer. maybe its because the clutch is moving further out.
Old Jan 16, 2008 | 05:53 PM
  #534
dmontzsta's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: KINGQUAD450
<div class="FTQUOTE"><begin quote>Originally posted by: EdKatt
Mine blew up!! Just joking guys. Scared ya. I havent taken my rollers out yet and I know some have had yours out a little while so I just wanted to make sure.</end quote></div>
funny you should say that. Never ran this one much since they overhauled it under warranty the first part of November. They pretty much made a new engine out of pieces.</end quote></div>
What exactly happened to it?
Old Jan 16, 2008 | 05:54 PM
  #535
EdKatt's Avatar
I think mine was a little louder after removing the spacer.
Old Jan 16, 2008 | 05:57 PM
  #536
thanks edkatt. it makes me feel a little better. have any of you changed wheels and tires? how big can you go?
Old Jan 16, 2008 | 06:21 PM
  #537
EdKatt's Avatar
airmobile has changed his wheels and tires on his. he will tell you the size.
Old Jan 16, 2008 | 08:56 PM
  #538
KINGQUAD450's Avatar
it started using oil. using it real bad we switched to 20-50 racing oil(supposed to stop oil consumption in racing engines) so we could get the last rip into Hatfield and McCoy and it was using a half a quart in less than 20 miles withthe motor heading down hill it would smoke like a frieght train. Seems fine now they put in a new crank, rod,brgs,piston and rings,and cylinder case and other small parts. It smoked a little from day one but I just figured it needed broke in well it never got better just a lot worse
Old Jan 16, 2008 | 09:04 PM
  #539
dmontzsta's Avatar
it started using oil. using it real bad we switched to 20-50 racing oil(supposed to stop oil consumption in racing engines) so we could get the last rip into Hatfield and McCoy and it was using a half a quart in less than 20 miles withthe motor heading down hill it would smoke like a frieght train. Seems fine now they put in a new crank, rod,brgs,piston and rings,and cylinder case and other small parts. It smoked a little from day one but I just figured it needed broke in well it never got better just a lot worse</end quote></div>
Was this after modifying it? what mods were done when this happened?
Old Jan 16, 2008 | 09:38 PM
  #540
like I say it wasn't right from day one with no mods but got progressivly worse
