LT80 - Fixed Drive Face
Old Aug 27, 2013 | 09:52 AM
  #21
koslt80's Avatar
Yes roller plate has got a "lip"
So u think the starter gear and key will be ok?
I ll only need a new fixed drive face the washer behind it and the roller plate?
thanx for ur help!
Old Aug 27, 2013 | 11:40 AM
  #22
LT80's Avatar
LT80 Expert
You have a long spacer. Short spacer measures 1.275. NO washer is needed for you.
It seems that it came loose for another reason other than no washer..Make sure the washer under the nut is a spring washer.
No matter, let's get this one put together correct.
The pic shows me that you have not removed the cover to clean and inspect the variator and rollers.
FYI: there is a guy on ebay that sells the whole front clutch.
Seeins you need the fixxed face (the fixxed face spins on the crankshaft splines)(and unknown damage inside), and roller plate, that complete kit may be a good deal for you.
http://www.ebay.com/itm/SUZUKI-LT80-KFX80-COMPLETE-FRONT-DRIVE-CLUTCH-87-06-/400257501089?pt=Motors_ATV_Parts_Accessories&hash=item5d3134c7a1&vxp=mtr
Old Aug 27, 2013 | 12:06 PM
  #23
koslt80's Avatar
long spacer for sure!
Suzuki parts list catalogue mentions that the spacer is 1.273 long and the washer 0.118 inches.
Mine is 1.38 total so that should be almost correct. No need to install a washer then.
I cant figure out why the starter gear and the roller plate were rubbing together so i can prevent this from happening again
So u saying i should only buy the complete front clutch kit and no starter gear
Old Aug 27, 2013 | 03:09 PM
  #24
koslt80's Avatar
I 've changed the rollers recently with new ones. There isnt any damage inside the variator.
Nut was loose when i removed the engine cover to inspect whats wrong. The washer is not a spring one but its the original washer. I have to replace it with a spring washer?
Also noticed a lil notch on the roller plate. Should the plate's notch slide onto the key and lock there?
Old Aug 27, 2013 | 04:53 PM
  #25
LT80's Avatar
LT80 Expert
Seeins we know someone was into the clutchs, It's probable that they lost the spring washer and used another type.......wrong.....
Yes you need the Suzuki washer that goes under the nut and make sure it's on the correct way.
Part number 09164-12020
The starter gear should be fine. Just clean it up a lil with a file.
Yes, the notch in the roller plate needs to be aligned with the key on the crank. The key only sticks out a little but it works.
"I 've changed the rollers recently with new ones"
Are you saying that you replaced the rollers, ran it, then this happened?
FYI:Once we get this together correctly and the nut impacted on, it should be fine.
Old Aug 27, 2013 | 05:25 PM
  #26
koslt80's Avatar
Had it in a workshop for the service didnt do it alone
Yes replaced rollers with original ones and got a new piston.
Ran it for a total of 5-6 hours then heard the weird sound!
I have that washer 09164-12020 installed but not sure whats the correct way
The key is pretty shaved dont think it will hold the plate.
I m starting to believe that all these happened cause they didnt align correctly the roller plate on the key so plate was spinning and chewed the key and then the starter gear.
Is this a possibility or i m totally wrong on this?!
Old Aug 27, 2013 | 06:28 PM
  #27
LT80's Avatar
LT80 Expert
There we have it.
You're correct, key wasn't aligned with the keyway when assembled. Once it ran enough to spin the roller plate to the key, it loosened because of that creating a space and then it only got worse. Not long after, you noticed the trouble.
The key is hard. Surely you can get a new key but the old one should work with a lil filing/sanding to clean the edges up.
The key is for alignment mostly. It has minimal side pressure. It's when it's all bolted together tightly that holds everything in place.
Lay the spring washer on a flat surface. It won't lie flat. It'll either be dome up or dome down.
You install the washer dome out so the nut pushes down on it making it like a lock washer.
Jmuddin284
Jan 19, 2026 07:16 AM
greg74
Sep 10, 2019 03:03 PM
KingDingalling
Jul 29, 2015 10:55 AM
Derek Allen
Jul 22, 2015 09:25 PM
tporath
Jul 11, 2015 12:31 PM
