No power
Old Dec 28, 2018 | 08:49 AM
Below Average Joe's Avatar
Default No power
Hey all, I bought a z400 that needed a lot of work. So far I have replaced the frame and swing arm, and all new bearings for swing arm and assembly. I have also replaced the wiring harness as the old one was a hot mess. Now that I have the bike back together, I have no power to the starter. The bike has power as the dash lights come on. I suspected that the starter solenoid was bad so i replaced and still no power .If I jump the solenoid the bike will turn over. Fuse is new as well. I'm stumped. The bike Rand great before I tore it down. Any help is appreciated .
Old Dec 29, 2018 | 04:02 AM
Check the negative wire to solenoid, and the thin pos which comes from the start button. I don't know the 400Z, but most Suzukis have an extremely complex lock-out system so it will only start in neutral, could be that not wired right.
Old Dec 29, 2018 | 05:48 AM
The ground is good. I will have check out the start button wires again .Bike is in neutral. The green light is lit plus the foot lever is in neutral position. By pos I'm assuming you mean piece of s@$&
cueball89
Nov 10, 2004 08:33 AM
Vision
Jul 18, 2003 06:01 PM
weasle
Jul 2, 2002 05:37 PM
meaniegreenie
Jun 2, 2002 11:28 AM
mick49157
Feb 26, 2001 10:50 PM
