need help with LT80 - bogging down, only runs with choke on
Old Nov 14, 2002 | 11:07 AM
DSAPP's Avatar
Default need help with LT80 - bogging down, only runs with choke on
once it's warmed up and my kid runs it for about 5-10 minutes, it starts bogging down.... eventually won't run at all....
UNLESS you put the choke on.... then it runs fine.... after a few minutes of running with the choke on, you can turn the choke off and it runs fine for a little while longer, then it starts to bog down again, and you have to put the choke back on...
I just had the carb cleaned, and it still does this
what could it possibly be.... I can't take it to a shop, because it works fine unless it is ridden for a while... and no shop will do that
help please!
Old Nov 15, 2002 | 05:06 PM
LT80's Avatar
LT80 Expert
The LT80 carb has been known to go bad now and then.Little air passages get plugged,and if that is the problem,then the only fix is another carb. I suggest trying another carb.If you don't have access to one PM me and I will send you one of mine to try.
Other than carb,I'm thinking maybe crank seals.
keep us ionformed plz [img]i/expressions/face-icon-small-happy.gif[/img]
Old Nov 15, 2002 | 07:36 PM
garyc660R's Avatar
Take the carb off and clean it throughly with brake cleaner....the brake cleaner is excellent for those small passageways. Keep us up too date.
Old Nov 15, 2002 | 08:31 PM
JSsDS's Avatar
I'm not sure how the tank is vented on those but you could have a problem there or a bowl vent on the side of the carb. Without these vents, air can't be displaced by the gas thats trying to get into the carb. Just another idea.
Old Nov 16, 2002 | 10:21 AM
LT80's Avatar
LT80 Expert
Checking the vent IS a good idea [img]i/expressions/face-icon-small-happy.gif[/img]
Old Nov 20, 2002 | 11:44 AM
DSAPP's Avatar
how do I check the float bowl vent?
Old Nov 20, 2002 | 06:15 PM
JSsDS's Avatar
I'm not really familiar with that quad and I don't know which carb it has on it but most are the same. You should have a few hoses going to your carb, one is for the gas supply and the other(s) are vents.
1. Turn off the gas valve and remove the gas hose from the carb.
2. Run the engine long enough to run most of the gas out of the carb.
3. Pull the vent hoses off one at a time and blow compressed air into the hoses.
This should remove anything that is blocking them but you should make sure the air comes out the other end of the hoses just to be sure.
4. Blow the air into the vent nipples on the carb as you remove each hose and listen for the air to come out the gas hose nipple.
5. Reassemble, turn on gas and test ride
While the gas hose is off the carb, turn on the gas MOMENTARILY to make sure the fuel flows freely out of the hose. If not you may have a restriction in the petcock
Good luck
Old Nov 21, 2002 | 10:02 AM
DSAPP's Avatar
JSsDS
thanks![img]i/expressions/face-icon-small-smile.gif[/img]
I'll do that
Old Nov 21, 2002 | 08:35 PM
fish_bulb's Avatar
Same thing happened with mine last month. I had to clean it with carb-cleaner MULTIPLE times before it cleared out.
skittero
35
Mar 1, 2019 12:39 AM
chinkapin
Jul 14, 2016 06:58 AM
Ty Speece
Jul 2, 2015 04:59 PM
robj
Jun 15, 2015 08:45 PM
jayking232003
Jun 9, 2015 02:54 PM
