RAPTOR CUTTING OUT AND BACKFIRING WHEN RIDING UPHILL
Old Jul 26, 2003 | 12:25 AM
kyraptor23's Avatar
Default RAPTOR CUTTING OUT AND BACKFIRING WHEN RIDING UPHILL
when riding on an incline at around 1/4 - 1/2 throttle, my raptor seems like it loads up and backfires and cuts out. This is a new problem that just arose the other day. Could it be the floats? when i give full throttle, it clears up. It only happens when riding uphill. Suggestions???????
Old Jul 26, 2003 | 12:37 AM
dragomni's Avatar
My friends 02 Grizz did the same thing, he brought it in and the told him it need the valves adjusted and this was normal....
Old Jul 26, 2003 | 12:57 AM
sixsixT's Avatar
You may have some crud in your carbs causing the float to stick or the needle valve not to seal.
Old Jul 26, 2003 | 01:11 AM
raptor8's Avatar
when in doubt, adjust the valves! it's easy.
[img]i/expressions/face-icon-small-smile.gif[/img]
low fuel level, crap in the bowls, could be many small things. but it never hurts to adjust the valves. you can drop your bowls easily after you strip off the plastic for the valve adjust.. ya may as qwell do it all at once, eh?
Old Jul 26, 2003 | 02:45 AM
dragomni's Avatar
The dealer did the work on my friends, has been fine since, cost him a couple hundred bucks.
Old Jul 26, 2003 | 09:43 AM
RaptorOwner's Avatar
Well mine did the same exact thing especially at higher altitude than sea level and it was the jetting. I took it to the beach and it ran fine, went back to RedRock canyon same cutting out. Found out after swapping all the parts I could found out it was in the carb. Was way to rich. Leaned it up a bit from where Dyno Jet recommended and it stopped. Just an FYI.
Old Jul 26, 2003 | 06:56 PM
kyraptor23's Avatar
Well I just adjusted the valves and increased main dynojets from 148/150 to 150/155, since i believe i was a little lean. It seemed to help (maybe) but it still seems to be loading up and not quite running like it did. Its also idling a little rougher now and popping when decelerating in low rpms. I have my needle on the 4th notch and 3.5 and 4 turns on the air screws, 25 pilots. Could it be my floats, and if so, are they hard to check? I read sixsixt's post on the clear tubing. I was a little confused on where the carbs mate?
Old Jul 26, 2003 | 08:00 PM
sixsixT's Avatar
The mating surface is where the bowl and the carb body meet. Top of the bowl when it's right side up.
cbcole02
Sep 7, 2015 06:16 AM
DOAinNY
Jun 11, 2015 10:34 PM
Dpearson03
Utility ATVs
May 29, 2015 04:51 AM
blaze_master
May 26, 2015 11:18 AM
