Carburator Problems Help??
Old Aug 10, 2003 | 09:59 PM
sledgehammer650's Avatar
Default Carburator Problems Help??
I just got a buddies 99' big bear 350 and he wanted to fix it for him well the pilot jet was laying on the motor when i got it and i ordered a new pilot screw set from the dealer and it was to small we look it up for a 98 and the # was the same so we went through some spare parts. I think something else is wrong other than the pilot screw cause every time you hit the gas it wants to stall or even shut off. It will rev if you take it slow but not all the time. I was going to order a carb. kit but iam not sure what to order it for i have the serial# for it but that it i have not found any markings on it to tell what year it is. Is there a site like kawasaki's where i can type in the serial # and maybe get the right parts?
Old Aug 10, 2003 | 10:10 PM
CTRaptor's Avatar
Dos it have the same carb as the warrior or does it have an accelerator pump? If so its shooting to much gas into it and stalling out, a different spring should do the trick.
Old Aug 10, 2003 | 10:22 PM
where is this pump it has a white cap on its side thats about the size of a quarter? If thats it are your just saying i need to replace this spring?
Old Aug 10, 2003 | 10:30 PM
JakalWarrior's Avatar
A warrior has an accelerator pump....
This "might" help. Take off the float bowl, take out the rod for the accelerator pump, and either stretch that string and make it stronger or put a stouter one in from a pump pencil or something.
Old Aug 10, 2003 | 11:06 PM
Is the pump in the bowl or is it on the side?
Old Aug 10, 2003 | 11:53 PM
is in a lil hole on the side of the bowl. When you take off the bowl it will be sticking up. When you push it down it will shoot some gas at you. On a warrior anywho, I dunno if a bigbear has the same carb.
Old Aug 11, 2003 | 11:08 AM
It don't have one so i guess i have something else going on i don't get along with carbs. to well. Iam going to try to get a kit for it today. My buddie has two kids that are about to drive him crazy to ride it.
Old Aug 11, 2003 | 11:31 AM
warrior007's Avatar
yamaha has microfiche online, as does a few online retailers.
Make sure you check the parking brake switch at the handlebar. if its broke or activated it will idle ok but stall out and **** and moan when trying to rev.
Old Aug 12, 2003 | 07:07 PM
warrior007 is there a way to override this switch. It acts like its starving for gas.
Old Aug 12, 2003 | 07:10 PM
warrior007's Avatar
yep, just unplug it down under the front and tape up the connector. Even if it is not the problem (sounds like it is) it will help down the road to have it disconnected already eventually it will cause this similar problem.
Its Yamaha's safety design to not allow you to rev the bike with the parking brake on its on most all their quads.
Go to alba and look at the microfiche for 99 bigbear, handlebars and levers, its listed as part #9. It will either need disconnected or the wires connected together. I am pretty sure the big bear will be the same as the other yamahas and need just disconnecting.
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
Bob Maurice
1) Engine problems..
Jul 14, 2015 09:05 AM
