Warrior runs rough at idle, good above idle?
Old Jan 12, 2006 | 10:51 AM
grapestomper's Avatar
Default Warrior runs rough at idle, good above idle?
When I bought my 2000 warrior the seller said he thought the fuel was old and should be replaced. It didn't smell sour, but to be safe we emptied the tank and filled it with chevron gas. All I have done so far is to install a new spark plug, even though the old one looked good and tan.
Any ideas on why it would run rough at idle but run good driving it? I would assume if it were a gummed up carb it would sputter at ride rpm's. This is a stock bike.
Thanks
Allen
Old Jan 12, 2006 | 11:59 AM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
I would guess valves needing adjustment or it has a vacuum leak. Its possible the carb needs cleaning but probubly not.
Old Jan 12, 2006 | 12:56 PM
Kodiak660's Avatar
Valves is a good place to start......adjust them as mywifesquad said. That way you know they are set right.
Then if it still does it you may need to clean your pilot jet in the carb.
Old Jan 12, 2006 | 02:55 PM
Thanks.
Anyone know of an online book/ instructions for valve adjustment on the warrior like the one for the Raptor?
Allen
Old Jan 12, 2006 | 02:59 PM
Kodiak660's Avatar
Originally posted by: grapestomper
Thanks.
Allen
Did you get it fixed?
Old Jun 19, 2007 | 12:55 PM
fastquad02blaster's Avatar
Clymer in the only thing that I can think of. You have to order it and buy it though.
Old Jun 19, 2007 | 10:19 PM
StngGT350's Avatar
grapestomper
yes there is a manual on this forum for the warrior. there are ones for all Yamaha quads. just look for it, i found it and it is in PDF format. i think it is about 45megs so good size, hope you have a high speed internet connection. i am sorry i forgot who posted it, but they had a link to there site and there is where i found it.
Old Jun 21, 2007 | 07:24 PM
07Wolvey450's Avatar
yeah i would definitely adjust yuor valves. might as well clean out your carb while your at it. lol
Old Jun 21, 2007 | 09:26 PM
buckaroo50's Avatar
0 to 1/8 throttle is controlled by the pilot jet and screw. You are either too rich or too lean on the adjustment.
Turn it all the way in and then out 2 turns - this is your reference point.
With the engine warmed up turn it in until it idles rough (make a note) then turn it out until is smoothes out and keep turning it out until it runs rough again (make a note). Then you split the difference between the two rough running point settings (two notes) and that is your correct setting.
Hondapolaris8596
Jul 9, 2015 12:53 PM
sticky123
1) Engine problems..
Jun 14, 2015 07:36 AM
TJM
Jun 11, 2015 01:28 PM
Steven Bandemer
Jun 9, 2015 08:50 PM
hoopduerr
Jun 2, 2015 09:01 AM
