Rapture Clutch
Old May 11, 2006 | 11:37 AM
claytl's Avatar
Default Rapture Clutch
Has anyone figured out why there is one differant clutch friction disc in a Rapture clutch. What function does it serve?
Old May 11, 2006 | 02:08 PM
recon99's Avatar
Wow, this is the first time I saw someone mispell "raptor" so terribly wrong.
But the one disc that has a smaller friction surface goes on the end of the stack (I think the top of the stack, so it would be closest to the outside of the motor. If you look at the part of the clutch boss and pressure plate where the friction pads make contact you'll see one (I think it's the pressure plate) that has a smaller area for the pad to contact.
Old May 11, 2006 | 06:07 PM
claytl's Avatar
I know about that one but the second one in is small also and has a ring inside of it. That is the one i was questioning
Old May 11, 2006 | 11:38 PM
bodydropcris's Avatar
theres 2 smaller discs, one is 2nd from the back that has a clutch boss spring inside it, then one that is on the outside that contacts the pressure plate. i dont know what the boss spring does, but that one is smaller so that spring fits inside, and the outside smaller disc is because of the way the pressure plate is.
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
cdstang
Aug 31, 2015 07:52 AM
