Big Bear 350 4 wheel drive problems
Old Mar 7, 2017 | 08:05 AM
junior08's Avatar
[QUOTE=Jeff_Super_S;2811717]The right rear wheel hub is stiripped. The bike has a solid rear axle so the only way one wheel isn't pulling is because that hub is stripped. The front diff in not locked together so one wheel can turn when the other isn't. You just don't notice it until one rear isn't
junior08's Avatar
trying to figure out how to post on here
Old Mar 7, 2017 | 08:15 AM
junior08's Avatar
Default no drive on back wheels
i have 1993 big bear 350.yesterday i was in the woods, snow covered roads,i noticed my bike was spinning on level surface,when i finally got home i jacked it up and noticed that when i throttler her in gear the back wheels not turning,the side driveshaft is turning where it goes into the rear diff.Is my axle stripped.?on gravel road she moves okay
Old Mar 8, 2017 | 03:00 AM
Yes, you are now front wheel drive. It is possible the splines on the prop shaft from transfer case to rear diff, have gone but on a Big Bear it is usually the splines on the rear axle shaft have gone, in the crownwheel, very expensive to fix.
Stillonit
Jun 18, 2015 11:23 AM
volsgo30
Jun 4, 2015 06:07 PM
Steven Bandemer
May 27, 2015 07:39 PM
finbone
Aug 29, 2000 04:46 PM
caldwell
Oct 28, 1999 03:30 PM
