YFZ450 won't start---doesn't crank, oil light comes on
Old 03-13-2017, 01:22 PM
Sexton yfz 2012's Avatar
Originally Posted by dirtjunkie
Check to make sure the battery is fully charged.
Make sure the kill switch is 'off'
Make sure it is in nuetral
I have a 2012 yfz 450 just bought it 3 days ago road it yesterday fine and road it today and was headed home it started bogging a bit then died on me started back then dies again while I'm rolling after pulling the clutch in again so I jumped it and it started road to the house pulled clutch it again dies again now won't start back up by start button it will hit but not start
Old 11-23-2019, 03:18 PM
Esepato760's Avatar
Default 06 Yamaha yfz450 it wont start it has a new battery and new solenoid but wont start
I have a 06 Yamaha yfz450 I put a new battery and solenoid and it won't start.. i press the start button and it just does a clicking noise...need help
Old 11-24-2019, 03:48 AM
Here we go again, fourth time this week that someone has posted the same symptoms. Can be a bit more tricky on Yams as some have lock-out relays so you can't start them in gear, and they click too, but if the click does come from the main starter solenoid:-
First thing to do is put a 12v high wattage test lamp between earth and the pos post on the starter, switch on, press start button, if solenoid clicks and lamp doesn't light, faulty solenoid, or bad earth if you earthed your lamp to the engine. To tell which, earth the lamp to the neg post of the battery and try again.
If the lamp does light when earthed to the engine, you have a faulty starter. They can get intermittent when the brushes are worn, so testing the starter on it's own, or shorting the solenoid, doesn't always give the correct diagnosis.
Old 05-13-2020, 03:36 PM
John Rodriguez's Avatar
Originally Posted by Alex Walsh
yes, i got it push started. i took it to my friend who works on them and it turns out yamaha is known for having "a little red wire" that usually goes bad. im guessing its the starter button relay. he replaced it and now it runs perfect
can you send me a picture of the red wire
  #15
Old 07-14-2020, 04:48 PM
Jason Blakley's Avatar
Default What Red Wire???
please, could you send me a pic, or location for this elusive wire?!?
I’m working on one now that is doing exactly as you described. It will run perfectly, if I jumper the solenoid. Both the neutral and clutch switches test fine. With the key on it will run, turn the key off and it kills it. With the key on, if I hit the start button, the red (oil?) light comes on. I’ve checked everything I can seem to find, and can not figure out why it won’t engage the starter. The solenoid does not click. I took a working solenoid off of my other bike and it still won’t crank. And the original one works on the other bike too. So that’s ruled out.
please, what red wire are you referring to?
  #16
Old 07-15-2020, 10:41 AM
barongan's Avatar
Will be fun follow
  #17
Old 07-16-2020, 02:05 AM
Alex Walsh posted that about the red wire 10 years ago, and if you read it properly, he got it fixed by a Yam mechanic who didn't tell him where the wire is.
Ryan Neel
10-18-2018 02:22 AM
Kb43
Technical and How-To Articles
11-19-2016 11:21 PM
mckroney
01-11-2007 06:56 PM
MCBRIDESTER
07-08-2003 07:42 AM
suzuke
09-11-2002 11:53 AM
Quick Reply: YFZ450 won't start---doesn't crank, oil light comes on
