1986 yfm225 starting problems
Old Jan 21, 2023 | 03:49 PM
Ryanw24's Avatar
Default 1986 yfm225 starting problems
Hello I’m new to this forum, I have a 86 yfm225 and when I got it I used starting fluid to see if it’ll start and it ran for maybe 20 seconds and then I shut it off to work on it but now that I have the carb clean and everything ready to ride it’s now not wanting to even run timing is perfect valves are adjusted and has fuel air compression, any idea of why will help I’m not too good with four wheelers so maybe I missed something…
Old Jan 22, 2023 | 02:59 AM
Check it still has a spark. Fit a new plug anyway, or the old one if it hasn't fired up on a new plug you have fitted. Double check the carb has been put back together correctly and that fuel is getting to the float chamber. Check the inlet manifold for cracks, Yams are prone to this, and they are most likely to crack while you have been working on the carb.
Old Jan 22, 2023 | 12:38 PM
Ryanw24's Avatar
Ok I appreciate it, I’ll keep you updated if I get it running I was going to get a new carb anyways it’s kinda old.
Old Jan 22, 2023 | 06:13 PM
Ryanw24's Avatar
Update: It runs I drove it a couple times and it’s idling but it does need a new carb this carb is old and it’s bogging but thanks for the help I appreciate it.
Old Jul 15, 2023 | 05:15 AM
EllenAustin's Avatar
Thanks for the advice, I will try it. Have you looking for credible websites to find online essay examples but are having trouble finding any? You can Visit This Link if that is the case. This website has many top-notch essay sample downloads that will enable you to complete your writing assignments on schedule.
jush
1) Engine problems..
Mar 26, 2020 03:49 AM
4zinger60
Aug 2, 2014 01:48 PM
advnchr
Mar 4, 2010 12:04 PM
bubbasbimmer
Dec 13, 2009 08:28 PM
MetalMulisha6661
May 19, 2006 03:29 PM
