The clutch rebuild...
Old Dec 10, 2002 | 02:05 PM
jessiejames's Avatar
Default The clutch rebuild...
I am in the middle of rebuilding my clutch and I got heavy springs from alba. I have noticed that when I tighten the springs all the way down that the washers on the bolts do not look like they can handle it. They look like they are bending and the springs might push past the washer.
Anyone done this that can give some advice maybe I am doing something wrong....
Old Dec 10, 2002 | 05:33 PM
bump
Old Dec 10, 2002 | 06:13 PM
RacinJason's Avatar
make sure the cluth face is in correctly...otherwise this sounds like you may have a problem...take a deep breath and re-check
BRAAAP
Old Dec 11, 2002 | 11:08 AM
I dont have the cover back on yet so I will definitly take it back apart and recheck things.
Old Dec 11, 2002 | 04:26 PM
87Banshee250sx's Avatar
Get new bolts. I had the old stock bolts with the normal ring washers, and they bent and one actually broke when I pulled my clutch lever in (Trinity HARD springs). I replaced all the bolts with new ones from my Yami dealer with the thicker washer connected to the bolt head. Shouldnt have any more problems!
-nick
Old Dec 11, 2002 | 05:32 PM
Are they the stock bolts or do they offer different ones do you know the part number??
Old Dec 17, 2002 | 03:20 PM
I found the problem I was not matching up the dots on the pressure plate and the hub.
Thanks every one for the help
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
cdstang
Aug 31, 2015 07:52 AM
