1995 King Quad Rear Axle Replacement
Old 12-06-2010, 11:00 AM
RamperCamper's Avatar
Default 1995 King Quad Rear Axle Replacement
I need to replace the right rear axle of a 1995 King Quad. I have the axle (shaft) on order. I was told that it is as simple as pulling the old axle out and sliding the new axle in. Is that all there really is to it?
This is my first ATV so I ma new at all of the this.
THANKS
Old 12-12-2010, 07:50 PM
twright205's Avatar
Default help me and him please
just picked up a 1994 kingquad Lt-f4wdx.... but while trying out the plow. I apparently lost the rear left half shaft, (the dog bone looking thing) sorry can't seem to know how to add image.
I am chatting with the guy who sold it to me. I do now notice that it didn't have the cv boots... anyway, can anyone point me towards where a used rear shaft might be located. and a fair estimate on if I have a pro work on it?
much appreciated,, I did pick up a clymer's. but would like to hear from so of you who have been around these quads
Old 12-12-2010, 08:46 PM
ba300's Avatar
Orginal Trespassers
helped a buddy of mine do a 94 and it was simple.
take the center nut off undo shock and swing arm off slide off end of axel then take a big screw driver and pop out the axel then push new one in and put back together.
Hope this helps
Old 12-12-2010, 08:51 PM
ba300's Avatar
Orginal Trespassers
Where did it brake at???????
u-joint or shaft
Old 12-13-2010, 06:03 AM
twright205's Avatar
u joint,, looks like part of it just sheared off.
Old 12-13-2010, 12:12 PM
ba300's Avatar
Orginal Trespassers
for oem parts I get mine at Chaparral-racing Great price and fast shipping.
or take it to your local driveshaft shop and they can hook you up.
Hope this helps
Old 12-13-2010, 08:32 PM
Sisco1957's Avatar
I have looped a piece of small chain through the u-joint and hooked it to a slide-hammer.
Old 12-25-2010, 03:43 PM
twright205's Avatar
Default awaiting fix
they guy I bought it from, took it to his atv guy, now apparently when he was moving it around in his garage, he started it up, tried to drive it, and the cv joint broke on the other, right rear drive shaft... can anyone tell me if there were some with boots and others without boots covering these areas... my clymers book states they should have boots, but the guy fixing it says that there were a number of different shafts used around that year...
what do you all think
Old 12-26-2010, 08:49 AM
papa hogg scoot's Avatar
Look up an parts break down of that year!! But IMO they all had cv boots on them quads... go to ronniesmailorder.com select atv,then model, then type,look up part needed and it will show you what it had from factory...[ go to oem parts]
Old 12-27-2010, 06:31 PM
Kerbbirds's Avatar
the cv man has complete axles on e-bay or call 1-800-338-2326
buckshit
09-24-2015 08:49 PM
Scott-Leigh
06-06-2015 09:10 AM
hoopduerr
06-01-2015 08:22 PM
blaze_master
05-26-2015 11:18 AM
Quick Reply: 1995 King Quad Rear Axle Replacement
