help diagnose stator
Old Jan 10, 2022 | 12:19 PM
  #51
thatguy714's Avatar
Just a dude
Originally Posted by LynnEdwards
Most stators have three separate coils of wire in them. Yours may only have two since you may not have the high voltage AC power winding for an AC powered CDI. As mentioned before, look for the Black/red wire soming out of the stator. It would probably be one of the loose wires. If you have it then you have the third winding. If you don't, you don't have the third winding.
Winding 1: (Battery Charge winding) This winding is several hundred turns of wire of heavy gauge wire. It is connected to the yellow and white wires. You should measure 1 to 2 ohms between these wires. But remember that you don't need this part working for the quad to start up and run. It will run off the battery for long enough to verify the ignition system is working. If you have problems here then address them later once the quad runs.
Winding 2: (Ignition Trigger Pulse) This is a small winding (a pickup coil) which is mounted outside the flywheel. It tells the CDI when to fire the spark plug. One side of this coil is tied to ground. The other is usually a blue/white wire which goes to the CDI. It should measure 150 ohms or so to ground.
Winding 3: (AC Ignition Power) You may not have this winding if your CDI is DC powered. It consists of thousands of turns of fine gauge wire, It generates moderately high voltage (up to several hundred volts at high RPM's) to run the CDI. This winding is grounded on one side, the other side usually comes out on a Black/Red wire. If you have this winding it should measure 450 ohms to ground.
Measuring the resistance of these windings is quick and dirty, but not the best test. The best way to test the stator is to measure the AC voltage out of each winding while disconnected from the wiring harness and cranking the engine with the starter motor:
Winding 1: 9.5 volts AC (yellow to white wires)
Winding 2: 0.2 to 0.5 volts AC (Blue White wire to ground)
Winding 3: 85 volts AC (Black/Red wire to ground)
Followed this for a TaoTao ATA110B. Winding 1 was .7-.8, winding 2 - 0 (no typo, it read 0), and winding 3 was 73-74.
Thank you for the post even though it's an old one.
Old Jul 16, 2022 | 11:50 AM
  #52
TamsRottCrazy's Avatar
Machinedrivinmecrazy
Indeed PLEASE let us know! I am still working on mine, I thankfully found LYNNS schematics and pray that they'll be helpful when I get out to the garage later on today! These lil machines are about a pain in the A$*
Old Aug 26, 2025 | 02:04 PM
  #53
M.duncan60's Avatar
Default Tao rhino 250. Oil inside stator cover?
I have been having a intermittent spark issue. The coil and cdi were cheep so I just through new ones in and it seemed to work. However the issue returned. So I pulled the stator cover just to have a look and was surprised to find engine oil inside. I don't know much about these 2 strokes but Im guessing it should be dry in there. Am I mistaken?
Thanks for the help.
Old Aug 27, 2025 | 02:12 AM
  #54
According to the internet, the Tao Rhino is a 4 stroke and the stator runs in oil on most four stroke motorcycles & ATVs. Two strokes are different, because the crankcase needs to be as small as possible to hold the incoming air/fuel charge so, on two strokes, the stator is separated from the crankcase by a seal. The fuel/oil mixture probably wouldn't do the insulation on stator windings any good either.
Old Aug 27, 2025 | 01:23 PM
  #55
M.duncan60's Avatar
Yup! definitely a 4 stroke. My ignorance is showing. Still I didn't expect oil. After visiting u tube I watched several videos of oil pouring out of stator cases. Thanks for responding.
joe16066
1) Engine problems..
17
Mar 13, 2018 06:13 PM
FLASHLIGHTBOY
Dec 26, 2012 11:11 PM
LynnEdwards
8
Aug 28, 2012 11:53 PM
Jonesyscoob
3) General Discussions..
18
Sep 3, 2011 10:54 PM
champinejosh
19
Aug 28, 2010 10:29 PM
