Engine I.D. help required
Old Jan 22, 2011 | 10:13 AM
raps's Avatar
Default Engine I.D. help required
Hi Folks, new here, need some help identifying the engine in a Kymco atv, on the side of the crankcase by the oil drain plug is this number;- LA 30 underneath that is the production number, so, what is the LA 30 engine?? and where can I find information about it?, any help much appreciated.
Old Jan 22, 2011 | 12:45 PM
1sol2nv's Avatar
can ya get a pic of the engine? cuz my number is near the shift lever on the left side of the atv (while sitting on it). an d i think most chinese engines utilize the cg engines but i could be wrong.
Old Jan 23, 2011 | 04:32 AM
raps's Avatar
Default Engine I.D.
Thanks for your reply, I'm more in the dark about posting picture's than I am about this engine, but I can tell you it's a 4 stroke overhead cam, 2 valve, air cooled single, and could be anything from 125cc to 200cc in size. gears, forwards, neutral, and reverse are selected on the right hand side of the atv as you sit on it, transmission between engine and gearbox is by belt and pulleys, gearbox to rear axle is by chain. Twin drum front brakes, hydraulic disc on the rear. hope this helps and thanks for any help.
Old Jan 23, 2011 | 01:52 PM
LynnEdwards's Avatar
Electrical Expert
I don't know anything about Kymco, but your description sounds a lot like a GY6 engine. They are typically 150cc but can be other sizes too. Do a google search for GY6 engines and compare your engine to that. Look for the plastic shroud that covers the cylinder cooling fins.
Old Jan 24, 2011 | 03:02 AM
raps's Avatar
Default Engine I.D.
Hi, thanks for the input, it's definitely not an GY 6 engine, no plastic shroud or fan.
Old Jan 24, 2011 | 01:25 PM
raps's Avatar
Default Engine I.D.
Cracked it!, it's a Kymco MXU or MXER 150cc model no. LLB1-900 approx 2004 to 2005, all I need now is a new starter motor
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
RickyMac
Mar 5, 2016 07:27 AM
U2OFlyer
Aug 5, 2015 12:46 PM
Nondem
Where to Ride
Jul 23, 2015 07:38 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
