one HOT p650
Old Aug 25, 2002 | 05:20 PM
iamwoody's Avatar
went riding today after i got my exhaust nuts back on and my 650 was overheating soo bad that antifreeze was gushing out of my quad any help?
Old Aug 25, 2002 | 11:23 PM
Kawi650's Avatar
is your rad full of mud? leak around a clamp?
Old Aug 25, 2002 | 11:28 PM
RINCON's Avatar
if it's muddy it could be clogged and boiling over. i've heard of a few ppl with this problem, one had a stick jammed up in the rad, and the other one the bracket broke and then the fan motor hit against the rad, causing it to leak.
Old Aug 26, 2002 | 12:17 AM
yamahagye's Avatar
Also, check to make sure the thermostat is not stuck closed. Is your fan coming on like it should? You mentioned that you got your "exhaust nuts" back on. If you took the exhaust off, you may have an exhaust leak which will cause your quad to run lean.
JaMeS
Old Aug 26, 2002 | 11:09 AM
trx450's Avatar
iamwoody---As Kawi650 mentioned, Check the REAR side of the radiator. Mine gets clogged easily with mud thrown up by the tires in RH or LH full lock turns. Just something the remember. I clean mine after each ride, I have had no overheat problems.
Do you ride WNF near Nelsonville, too? I live near Delaware.
Old Aug 31, 2002 | 04:09 AM
yamahagye's Avatar
Well, did you find out the problem yet?? I think everyone in the forum is having a contest to see who can be the most helpful at solving problems.....Don't leave us in the dark! we must know.[img]i/expressions/face-icon-small-cool.gif[/img]
JaMeS
Old Aug 31, 2002 | 06:40 PM
iamwoody's Avatar
well after going through it all the only thing leftn to do waas the first thing listed in the owners manual for overheating...... The spark plugs. i pulled bothed out and they were both corroded on the tips???
put in new ones today and rode out behind the house for a hour and no overheating so i let it idle in the driveway and it is still good
thanks for all the help from everyone!!!!!
bye the way i go to wayne quite often maybe we can hook up sometime and ride
thanks Jim[img]i/expressions/face-icon-small-happy.gif[/img][img]i/expressions/face-icon-small-mad.gif[/img][img]i/expressions/face-icon-small-sad.gif[/img][img]i/expressions/face-icon-small-shocked.gif[/img]
Old Sep 3, 2002 | 12:17 AM
Kawi650's Avatar
interesting... Never seen sparkplugs only cause overheating.. normally I would think the bike would work like ($##1keX) first, then overheat.
tommyboy84
Utility ATVs
14
Oct 4, 2002 11:51 AM
kawirob
Jul 19, 2002 10:59 AM
Uncle
Jul 5, 2002 10:38 PM
lackdog
May 26, 2002 08:16 AM
