Lectron 46 HELP
Old Jun 13, 2004 | 03:19 PM
busmechanic's Avatar
Default Lectron 46 HELP
if I remember right. you can go as low as 400 grit on the slide. and its only necessary to polish the side that faces the engine.
Old Jun 13, 2004 | 03:23 PM
huskerjim's Avatar
ok let me get this right, use 1000 girt and only polish the engine side correct? and I will not be able to use the factory thumb but the after market twist will work? do I have all this right? also when using the sand paper do I just go up and down motion?
Old Jun 13, 2004 | 03:34 PM
BlackHawk's Avatar
You only NEED 400 grit, but you can go as high as you want. If you want to make it shine that wont hurt, perhaps it will help more - I'm not sure I'm thinking of trying to polish mine but have not yet. I sanded both sides and even gently on the edges to make sure everything was smooth. Once you get the sanding all done the next step is to adjust the idle & air / fuel mixture screw. I'm not sure the slide will be a night and day difference, but adjusting the carburetor right will be!
Old Jun 13, 2004 | 03:44 PM
the factory thumb has to be modified to work. twist or moose billet thumb will work. I have a twist on mine right now. if I like. the moose and cable will be for sale. up and down with that fine of sand paper will be fine.
Old Jun 13, 2004 | 08:14 PM
  #15
huskerjim's Avatar
the factory thumb has to be modified to work. twist or moose billet thumb will work. I have a twist on mine right now. if u like. the moose and cable will be for sale. up and down with that fine of sand paper will be fine.
What is a moose? Guys I'm a little older than most and need educated a little on some parts...
Old Jun 13, 2004 | 08:36 PM
  #16
BillDS650's Avatar
Moose Thumb Throttles
Old Jun 14, 2004 | 01:53 AM
  #17
BlackHawk's Avatar
Jim,
As you can probably tell, Moose is a brand name. If we throw some lingo at you that you aren't sure about be sure and ask, sometimes we get so used to the lingo we forget that there might be people who don't know all of the brands etc.
It really figures that NOW - after I already bought my Billet Thumb Throttle that Moose has the Blue one. Oh well, I think all in all the natural aluminum would have been my second choice and it gives me the option to polish it at some point if I ever want to.
Old Jun 14, 2004 | 03:25 AM
  #18
along with the link that billds650 posted. there is a pic of the one I have on my bike in my pics.
Old Jun 14, 2004 | 03:29 AM
  #19
sorry, I should have been more specific.
Old Jun 14, 2004 | 05:28 PM
  #20
222's Avatar
222
Originally posted by: Entomber
I know my cable is too long an hence it might be binding up a bit under the tank. I'm going to order another one but at certain times I was using my entire arm to push that thumb throttle. It's not so bad in the dunes but on a track where you vary the thumb throttle especially for setting up big air, you need to hammer it before flight, and gun it when you land. Iwas giving a YFZ450 a good run until my thumb fatigued.
Blackhawk where did you get your cable from? I can order it from Terry Cable but its about 2 weeks to get here.
The thing is tomorrow I'm going to anothe track.
If it is stiff everywhere, it is the cable, cable routing, or throttle. If it is stiff off of idle, then it's carb adjustment.
Just call mr hp. He'll get you the EXACT cable you need for your setup (and they're in stock).
222
Hightower
Apr 27, 2004 09:19 PM
918sTaxi
Oct 30, 2002 11:41 AM
QUADLOCO
Sep 11, 2002 01:15 AM
Slobanshee
Feb 22, 2002 10:42 AM
the500bansheepilot
Feb 5, 2002 03:18 PM
