TM45 vs Lectron 46 vs KMS EFI
Old Jan 3, 2006 | 11:28 PM
  #21
OregonDunePatrol's Avatar
Default TM45 vs Lectron 46 vs KMS EFI
It might be possible to plug the sensor hole when you move it to another quad. But, you'd have to have a plug for that with the right threads. Also, you'd have to quick connect your electrical connections. The data lines should NOT be cut, so, this would make it easy to move from quad to quad. So, if you can overcome the plug issue, then I would say you should be able to move it from quad to quad. You might want to check with Innovate to make sure though first. By the way, every sled and every quad that is in our R&D shop (now more than a total of 8 units) all have these sensors on them - all run leaded fuels - some 2 stroke & some 4 stroke. Not one has failed yet. We use them to get base line EFI settings for Nitrous sleds- Yes, they are that accurate!
Hightower
Apr 27, 2004 09:19 PM
Forcefed
Jan 9, 2003 11:32 AM
DS650runner
Jan 4, 2003 08:46 AM
918sTaxi
Oct 30, 2002 11:41 AM
Slobanshee
Feb 22, 2002 10:42 AM
