Rancher 350ES Leaking Gas
My Rancher was leaking gas. I put a new kit in the carb. It still leaks at times. It will start running rough(flooding) sometimes and when I shut it off it will leak all the gas out the overflow tube. This just happens now and then. Can anyone help me with this? thanks
Did you replace The needle valve and needle valve seat??
does the float rattle or have liquid in it ???
Thanks, It is a 2001 model. I don't know of a bulb. I don't think it has one. I replaced the needles etc. with the kit. There is just something causing the float needle to hang sometimes I guess. One small enginge man told me to put fingernail polish around the seat. If it were leaking there it seems it would leak all the time. Thanks
I hadn't thought about cleaning the fuel tank etc.. It did sit for a long time before I got it.
Thanks
Thanks
honda rancher 350es ran fine and then just started running as if carb flooding starts fine and takes throttle until u put it in gear and then it chokes out in about 10 to 20 feet; when stopped, after a few minites it leaks a puddle of gas about size of 2 hub caps out of fuel overflow line (I think, the line comes off bottom of carb) it hasnt been sitting up
exmotocrosser
Sep 13, 2019 06:12 AM
