Honda Forman front diff lock?
Old Jun 6, 2007 | 09:02 PM
Gimpster's Avatar
Default Honda Forman front diff lock?
Differential parts link
I believe he is talking about installing them between item #18 and #19
I have added multiple shims (#19) to lock them in the past, there is also another way.
The pennies will not come out once the center section is bolted together ( the ends that are not numbered on the parts picture that house the limited slip assembly, the pennies will stay inside )
There is another way to do it without adding any shims. The teeth parts that slip (assembly 17 is individual teeth) are installed in a certain order to make the assembly slip. kind of in a step type pattern. If you take this assembly apart and do not step the teeth when reinstalling, alternate them instead, it will lock the front end solid.
If you have a service manual (Honda) it shows the propper pattern install them. Alternate them instead to lock the front diffy.
By the way, once this is done it will steer harder than heck
Just for the record, I did not tell you how to do this.... hehehe
----- Gimp -----
Old Jun 7, 2007 | 03:02 AM
mykool61679's Avatar
you can also hit your front brakes and this will make your fronts spin together, for free.
Old Jun 7, 2007 | 12:23 PM
Twin420s's Avatar
I may give the 6 cent locker a try........ but I'm a little short on cash right now.
Old Jun 7, 2007 | 02:22 PM
surelly09's Avatar
seems like a lot of work... have both my diffs locked in my toyota pick up... and sometimes its really frustating trying to turn... even if the tires are turned all the way the truck doesn't turn because the outside wheel isn't allowed to travel faster than the inside wheel... i think it would take away from my riding experience as whole... no matter how much it improved my performance in a mud hole...
Old Jun 7, 2007 | 06:26 PM
  #15
magicalj's Avatar
For those who know how to do this, Do you need to disassemble the differential to add the pennies?
Old Jul 12, 2010 | 01:49 PM
  #16
MuddinForeman's Avatar
Those of you who have locked your front diff whether by aftermarket, using pennies, or any other ways. ... can you still switch from 2wd to 4wd if you had that option originally or does it become fully 4wd..?
Just curious bc i dont want to lose the option of 2wd because its just fun!!!
Old Jul 12, 2010 | 08:12 PM
  #17
95wolv's Avatar
Talking
Originally Posted by CatKrazy
You do know that you can lock your front end for 6 cents dont you.
Yep thats right. You can lock the rancher runicon foreman and rincon with 6 pennis. Just stivk them in the slot were the thrust washer is and the spring will stay compressed and your front end will be locked! My father in law did this and it works!
The only problem is He is still pissed,because he still cant hang with me and my locker!!!
the way you spelled it, at first I thought you were doing something immoral to your Honda !!! and with 6 of them, no less !!!
Old Jul 14, 2010 | 09:05 AM
  #18
TLC's Avatar
TLC
The reason most ATV have 3 options, 2wd,3wd(4x4) and true 4x4 AWD diff lock is that in AWD the ATV is almost unsteerable and only used in slow low traction conditions.
Full time diff lock would not be much fun.
Old Jul 14, 2010 | 04:24 PM
  #19
Specta's Avatar
Boy, no kidding. I think my arms would fall off after just a few hours of riding.
Old Jul 15, 2010 | 09:11 AM
  #20
williams8899's Avatar
It is really simple and unbelieveable how this is done! I couldnt believe it either. The pennies stay in place and are exactly the right size to keep the washer from flexxing which makes the clutches stay in the locked position
Auto Parts
Car Parts
Reactant
Mar 30, 2022 02:08 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
Gtsordo
Jul 13, 2015 10:38 PM
jettman
Jul 6, 2015 12:16 PM
Mphillips
Jul 2, 2015 07:20 PM
