p650 no 4x4
we have a p650 4x4 that wont go into to 4wd i took the actuator off and the motor isnt
frozen put a tester on the switch and it opens and closes does anyone know what else
to check for?? it dosent make any noise when you hit the switch, also the belt tensioner
used to do it thing when you turned the key on and off that no longer makes sounds either???
It's a good chance that the two items are related. The engine brake actuator is tied into the 2wd/4wd actuator.
Are the 2wd & 4wd lights flashing when you turn on the key. If so what is the interval between the flashes?
Is the speedo reading movement?
If you need more info maybe I could fax you the required pages from the service manual.
You have checked the fuses right? Anyway, here is the test for checking the braking actuator. Use a hand tester and check these resistances on the actuator plugin. Red-Black, 3-15 ohms. Orange-Blue, 3.5-6.5 kohms. Yellow-Blue, 630-5,330 ohms. Let me know your results.
The manual lists 5 reasons for the brake actuator not to be operating properly. 1) actuator failure (test above), 2) actuator controller power supply (check to see if close to battery voltage at controller), 3) speed sensor failure (might be worth checking, some guys have had problems), 4) F/R detecting sensor failure (1.2-1.6 kohms resistance) & 5) actuator controller failure (test controller output voltage, 5-12 volts to braking actuator).
I still think the two problems are related. Too big of a coincidence not to be.
Let me know if you need more info.
Steve
Steve
kawirob
07-19-2002 10:59 AM
lackdog
06-11-2002 09:23 AM
