Have the clutch in the 400 2x4 but need help
Ok, The kit that Rick sent me was a Plain spring for the primary, (Looked black to me) and a purple spring for the secondary and the weights. this did make a difference in mid range and top end. but i still dont have any low end, it still stumbles for about a second or two when i hit the gas. i am running a 260 on the main jet but i still think i am running a 25 on the jet pilot. i still have the stock carburator on. when i took it out for a ride today the spark plug is dark brown where it is gapped but the rest of the plug looks a little wet like its not burning all of the fuel or its getting too much oil. i still have the stock oil injection on. but i plan to get the oil block off kit. can anyone offer suggestions with the stumbling i have during take off. i forgot to say this , when i am running at about 1/4 throttle it seems like it misses quite a bit.
i did race a warrior today and i beat him by about 8 bike lenghts but he got me off the start for about 2 bike lengths. i also raced a stock 250r and beat him at the start and pulled strong at mid range and got ahead of him about 4 bike lengths, then he passed me after about 300 feet soundly. is this normal? or do i still have to do something? also forgot to tell you i have trail porting and a trail pipe
Call Rick and ask him but it sounds to me you need more engagment rpm.
i'm not familiar with that 34mm carb but,you should at least
go for a 270-290 main jets and needle i clip droped down as far the pilot jet,it doesn't do any big differences on a trail pipe.
it seem your secondary need a little tweaking,go for a 42-38 2-1 setting.
the stock oil setting would be too rich,try to lean it up,if you want to remove it,beware,the only thing i will do is save weights,because the system work pretty well,and pre-mix become a pain in the *** with time.
The 25 pilot sounds a little small to me. I had a 30 in mine. It might be starving for fuel on the slow circuit. Try going up to a 30 and see what happens. Might not be it but it's worth a try.
Hey man what's going on, haven't heared from you in a while. Anyways the one thing that I can tell you about you 1/4 throttle is that the pilot jet is responsible for this area of throttle, so you may want to check it and also you may want to give Rick a call sorry if this doesn't help.
cdstang
Aug 31, 2015 07:52 AM
