2005 Polaris sportsman speedometer
need a little more info. saying it dont work is kinda wide range.
dose the speedo tell u ur speed? if not its most likly the right side hall sensor. located on the brake disk bracket. you can test the hall effect sensor with a 9v battery and a led.
dose the display function? if not it would most likly be eith a power, ground, or and igntion wire.
4x4 work? the awd indactor light come on? if not could be the switch, or the speedo. if the indacator light dose come on. it could be the wire to the speedo, or the other side of the coil wire going to the sure module that controls the other side of the coil wire.
the worst case could be the speedo has crapped out on ya.
bzdok1234
30
02-23-2016 01:55 PM
