Primary Clutch on 99 Polaris Scrambler 500
Old 03-25-2016, 08:43 PM
COwen's Avatar
Thanks for the reply and the help. I will make sure to check everything and will let you know how it goes and how well the clutch performs.
Old 03-26-2016, 09:08 PM
COwen's Avatar
Default Primary Clutch Replaced
The new clutch arrived this morning and is now on the bike. After taking a close look between new and old, the weights were the same but the one main difference is that the new clutch has a smaller diameter spring than the factory one. After install and being torqued to spec, I put all back together and fired it up. I must say, it works really good and is fast. Nice to see hard work pay off so a little fun can be had. Thanks again for all of the feedback on here.
Old 03-27-2016, 05:51 AM
You might experiment with the oem spring and see if there is any difference in performance. Either way sounds like a good deal considering it's about 150-170 bucks less than an oem clutch.
Old 03-27-2016, 08:05 AM
COwen's Avatar
I think I am going to keep the old clutch and buy a rebuild kit for it. Really, the only thing that I could see wrong was that the bushings came out of it and that is why had the knocking at idle. Plus, gives me something to tinker with and have a spare.
  #15
Old 03-27-2016, 11:18 AM
As long as the spider towers aren't grooved up where the buttons slide,there are plenty of rebuild kits around.Epi Complete Primary Clutch Rebuild Kit for Polaris Scrambler 500 4x4 1997 2012 | eBay
  #16
Old 03-27-2016, 09:00 PM
COwen's Avatar
Thanks for the link and reply. Now I seem to have another issue. When I bought this quad I knew the carb needed a good cleaning. I got that done, float looked and worked good, and the blew all orifices out with compressed air. Today it was being ridden and suddenly stopped and gas was pouring out of the drain plug out of the bottom bowl. Upon further inspection, noticed the drain plug screw had come out. I found it luckily wadged between the frame and skid plate. Reinstalled it but gas seems to still come out at idle but not while running?
  #17
Old 03-27-2016, 09:49 PM
Common problem on this carb to dribble a little at an idle. Float is hard to set right,but if you've been having problems,I'd go ahead and install a carb kit. Shindy Carb Repair Kit for Polaris Scrambler 500 2 4x4 98 02 Sportsman 500 4x4 | eBay
Carb has to be at a 45 degree angle and the tab must just touch the float pin with the float parallel to the carb body. Here's a good article on this BST40 carb and how to set the level.On a Ktm,but similar carb.http://www.advrider.com/forums/showthread.php?t=347184
Attached Thumbnails Primary Clutch on 99 Polaris Scrambler 500-2471649347_b2a1a773d6.jpg
  #18
Old 08-01-2016, 09:11 AM
Webz70's Avatar
COwen,
Hows that clutch working for you? i am thinking about buying one. holding up good? can you use a epi or the stock primary spring with it? any information would be appreciated.
Thanks
Dave
  #19
Old 08-01-2016, 07:52 PM
COwen's Avatar
Default New Clutch
Originally Posted by Webz70
COwen,
Thanks
Dave
Hey Dave,
New clutch works great and is flawless! I did not change the springs in it I just ordered a whole new one and am going to rebuild the old one with new springs when I get the time. I had been told that the after market clutches were not very good nor reliable but like I said, I have had no major issues. Sorry for the delay in answering, had to remember the password for this place. Take care and let me know if you have any other questions.
Asaran
06-02-2016 07:24 AM
thevarminthunter
03-23-2016 04:28 AM
madb63
03-22-2016 06:06 PM
Sebastian24
03-22-2016 01:14 PM
4bratsdad
03-21-2016 05:05 PM
Quick Reply: Primary Clutch on 99 Polaris Scrambler 500
