ltz50 quad no power
Old Mar 6, 2008 | 10:12 PM
  #661
JPLLTZ50's Avatar
Default ltz50 quad no power
JEFFINRIVERCITY GO ON TO MOTOJOCKEY.COM IN THE SEARCH BOX TYPE MINI QUAD,THEY HAVE A ALUMINUM WHEEL 3/90 MM BOLT PATTERN STARTING AT LIKE 40.00 EACH....... CLICK ON THE T9 PRO SERIES WHEELS ITS LISTS THE 3/90 MM FITS THE RAPTOR 80 AND DOESNT LIST THE LTZ 50 BUT ITS THE SAME BOLT PATTERN SO THEY SHOULD DO THE TRICK
Old Mar 6, 2008 | 10:16 PM
  #662
EdKatt's Avatar
RIDE, he bought that sprocket from kingquad450, but Kingquad ordered it from sprocket specialists. He said it took a long time to get, thats why he made his own 48 tooth sprocket.
I dont think you would want to do the clutch kit and sprocket together. Each gets about the same result so you shouldnt need both.
Old Mar 7, 2008 | 11:15 AM
  #663
jeffnrivercity's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: JPLLTZ50
JEFFINRIVERCITY GO ON TO MOTOJOCKEY.COM IN THE SEARCH BOX TYPE MINI QUAD,THEY HAVE A ALUMINUM WHEEL 3/90 MM BOLT PATTERN STARTING AT LIKE 40.00 EACH....... CLICK ON THE T9 PRO SERIES WHEELS ITS LISTS THE 3/90 MM FITS THE RAPTOR 80 AND DOESNT LIST THE LTZ 50 BUT ITS THE SAME BOLT PATTERN SO THEY SHOULD DO THE TRICK</end quote></div>
Sweet...I will look...wonder what offsets they offer..still half the price of the stock wheel..thx
Old Mar 7, 2008 | 12:18 PM
  #664
<div class="FTQUOTE"><begin quote>Originally posted by: jeffnrivercity
Sweet...I will look...wonder what offsets they offer..still half the price of the stock wheel..thx</end quote></div>
Looks like they are all 8" wheels....instead of the stock Suk 7"...looks like i would have to go to taller tires then?
Old Mar 7, 2008 | 12:45 PM
  #665
DSengineer's Avatar
Has been here a long time!
The stock tires aired down do a very good job of floating on the sand. From what I have seen with other kids quads running paddles they either dont have enough power to take advantage of them, or they just end up digging in. I plan on sticking with the stock tires until they need replacing...
Old Mar 9, 2008 | 12:22 AM
  #666
RIDE!'s Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: EdKatt
I dont think you would want to do the clutch kit and sprocket together. Each gets about the same result so you shouldnt need both.</end quote></div>
Thanks EdKatt, Yah I do remember now someone mentioning they had or they were having one made pages back. Thanks
Old Mar 10, 2008 | 11:18 PM
  #667
EagerJeeper's Avatar
KingQuad sold that to me. He ordered it but it from Sprocket Specialists but it was so slow to arrive that he fabbed up a 48 tooth sprocket. He was so happy with the 48 tooth sprocket that he sold me the 43 tooth sprocket.
I think for crawling through gullies and rough stuff a sprocket upgrade is a must for this machine. It's cheap and very effective. Ours still goes plenty fast for our kids. The sprocket is our only mod, although I do want to get the pipe from CT Racing for more low end power.
Old Mar 10, 2008 | 11:22 PM
  #668
I'd like to add a headlight to "the little slug". Has anyone done this? I'd like to wire it so that it comes on with the ignition.
Old Mar 11, 2008 | 01:18 AM
  #669
EdKatt's Avatar
It would be real easy to do.
Old Mar 11, 2008 | 02:40 AM
  #670
AIRMOBILE101's Avatar
Rebelgears.com
