Exhaust pipes stuck!!!!
Old Jun 15, 2003 | 07:33 AM
XxDumontRaptorxX's Avatar
Default Exhaust pipes stuck!!!!
I have big gun header and slip on pipes, they were clamped on together, and now they wont come off. We got the clamp off and pulled the exhaust out when we took the engine out, but the engine is back in now, and the pipes are still connected. There is some brown residue (sp?) around where the pipes come together. SEEMS LIKE ITS GLUED!!!! any suggestions??? We've tried muscle and heat allready.
Old Jun 15, 2003 | 03:27 PM
BlueLeader's Avatar
have you tried penetrating oil? be patient and let the oil soak in. reaply often.
Old Jun 15, 2003 | 04:31 PM
Ummm would WD40 work???? i dont have penetrating oil.
Old Jun 15, 2003 | 05:02 PM
BlueLeader's Avatar
that brown residue is probably rust. try the WD40. good luck.
just "jiggle" it. LOL.
Old Jun 15, 2003 | 06:03 PM
RAPTORAZ's Avatar
On a side note. Put a little anti-sieze on the slip joint and you won't have that problem next time.
Old Jun 16, 2003 | 02:14 AM
RaptorRacer1's Avatar
What type of anti-sieze do you use? I tried that once and it made a mess. When I fired it up the anti-sieze melted and dripped out of the joint.
RR1
Old Jun 16, 2003 | 09:06 AM
RAPTORAZ's Avatar
Permatex.
Old Jun 16, 2003 | 11:15 PM
Turtler's Avatar
I would try using an oil filter wrench on each side of the stuck joint and crank it in opposite directions. Try using those elastomer banded wrenches and you will produce an incredible amount of torque to break free the gunk. The elastomer bands should protect your pipe and silencer from cosmetic damage while trying this. Good luck.
Old Jun 17, 2003 | 02:16 AM
RepTaR660r's Avatar
im not sure but that dude sounded like he knew what he was talking about...
Old Jun 17, 2003 | 04:57 AM
The WD40 with me and my brother both pulling seperate ways worked out... took 10 minutes of work. Got the pipes back on si its too late to put the anti-sieze on, ill have the pipes off again in like 4 weeks to port and polish the head.
Valder
Nov 28, 2020 07:38 AM
fordfaithful21
Dec 7, 2015 05:52 PM
Jason Poulin
Sep 20, 2015 02:49 AM
Bonzhonda300ex
Sep 17, 2015 10:44 AM
antiguogrumete
Sep 5, 2015 03:41 AM
