32:1 0r 20:1
Old Jul 19, 2004 | 09:26 PM
BANSHEEBOY88's Avatar
Default 32:1 0r 20:1
i just bought a banshee and the previous owner ran it at 20:1, should i run it at that or should i run it at 32:1 will that hurt anything?? will I have to change anything if i change ratios. also he ran castrol and i want to fun klotz will that hurt anything???
Old Jul 19, 2004 | 09:38 PM
Sidewinder500's Avatar
I run the mix ratio that the oli manufacturer recommends which is 40 : 1 on the oil I use.
congrats on the new banshee!
Old Jul 19, 2004 | 11:06 PM
Devin246's Avatar
i did 20:1 for the 1st 3 tanks then switched to 32:1 once i mod with pipes and filter im gunna run 40:1 after rejetting.
Old Jul 20, 2004 | 05:28 PM
bump
Old Jul 20, 2004 | 06:36 PM
dragracer789's Avatar
No 20:1 is to much oil! IMO 32:1 is also. I personally run 42:1 Red Line, and used to run amsoil but red line burns alot cleaner. I have heard of people running 100:1 with the right oil so no need to worry about not enough oil untill you get up past about 52:1.
Old Jul 20, 2004 | 07:10 PM
well is running it at 20:1 bad for motor, or is it OK for the motor but i might be fouling some plugs every several tanks of gas.
Old Jul 20, 2004 | 09:23 PM
daputz's Avatar
When you increase the amount of oil you displace the amount of gasoline in the fuel mix.........which has the potential to create a lean condition. Run what the oil manufactor recomends. I personally have been running either redline or amsoil at 50:1 for well over a year, and have never had any oil related problems.
Old Jul 20, 2004 | 09:39 PM
well if i do change to 32:1 will i have to rejet????
Old Jul 20, 2004 | 09:56 PM
daputz's Avatar
The safest thing to do would be run some plug checks/chops. For the price of plugs...........consider it cheap insurance.
HiFlyinRaptorRyder
Jan 3, 2004 02:34 PM
gszilla
Aug 10, 2002 02:46 AM
mroux
Jul 22, 2001 11:37 AM
Blastermon
Jul 18, 2000 04:07 PM
ackergr
Nov 30, 1999 12:45 AM
