Anyone bump the timing on a warrior?
Old Dec 20, 2004 | 06:54 PM
VelociRaptor350's Avatar
Default Anyone bump the timing on a warrior?
I just found a degree key for the yfm350 motor and wanted to know if it gives any gains? I did a search and couldn't find anything.
Old Dec 20, 2004 | 08:17 PM
86LT250RFatty's Avatar
of course it will give you gains, but it also makes your motor run a lil hotter, as long as your still on stock CDI and compression, ide give it a try.
Old Dec 20, 2004 | 10:13 PM
Whats it worth? Should i expect a few hp or like .5hp
Old Dec 20, 2004 | 10:17 PM
JakalWarrior's Avatar
.5 or less prolly. Mostly it makes em a bit snappier and torquier. Really does bout nill for top end.
Old Dec 20, 2004 | 10:18 PM
YamahaAtvFreak's Avatar
Where did you din it, ill give it a try too.
Old Dec 20, 2004 | 10:24 PM
Vito's performance has the degree key, its like 20 bucks. That sucks, im looking to give the top end a boost, low end is sweet now, plenty of grunt, mid range is there, not where i want it to be but its getting there, but the top end lacks what i want. Is the only way to really boost the top end internal mods like a hi comp piston or a cam?
Old Dec 21, 2004 | 03:26 PM
id go wit a hotcam, from everything ive heard bout it, it is suppost to be great.
Old Dec 21, 2004 | 03:42 PM
stage 2 for top end
Old Dec 21, 2004 | 06:00 PM
stage 2 you need different springs right, it recommended?
Reactant
Mar 30, 2022 02:08 AM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
95wolv
Jul 17, 2015 08:13 PM
Reactant
Jul 16, 2015 10:29 PM
