OLD YAMAHA HELP!
OLD YAMAHA HELP!
OK, my buddy has a 1993 Yamaha Timberwolf 250. He asked if I could take a look at it for him, because I know more than he knows about engines, but not a whole lot. When I first got it, he said he has already bought a new battery, and a spark plug. When I started to work on it, I poured some gas in my the plug, and did get it to run for about 5 seconds, then it would shut off. Well after a few times of doing that, I ran into a new problem. The starter relay makes a clicking noise when I try and start is. Once in a great will, it will go, but not often, otherwise it just clicks. What will do I have to do? get a new starter relay? I cant try anything else because it dosent have a kick start or pull start. THANKS! schub
OLD YAMAHA HELP!
I have a 1992 Timberwolf and have a similar problem. The problem I have is a weak battery but I have a pull cord as a backup. After giving the bike a good run, it will start perfect on the electric for a day or so but then the battery will get weak and gives the clicking sound that you hear. Not enough juice to turn over. Charge your battery and it should give you a quick fix. If that works only for a couple of days you will need to replace your battery.
Hope this helps.
Hope this helps.
OLD YAMAHA HELP!
Well, I have tried hitting the start with stuff, and that dosen't work either. There is a brand new battery, and it still dont work. Sometimes I will get it to turn over, but other times it will just click. I was thinking the starter cyliniod would be the problem, but I'm not sure. I think my friend it going to take it to a mechanic though, but and more comments are apprciated! Thanks
09-23-2015 06:23 AM
