Electric Start Issues/Electrical issue
Old Jul 5, 2018 | 09:38 AM
fritz4000's Avatar
Default Electric Start Issues/Electrical issue
2007 Yamaha Grizzly 400 4x4
Pull Start is fine
Put key in and turn to on position. The neutral light comes on. Move red switch to run position and the neutral light goes out or dims and electric start will not function. Can use the pull cord to start in this position.
Also, when running, the lights will work, but when hit the winch button to extend cable, the engine cuts out.
Any ideas?
Old Jul 6, 2018 | 01:57 AM
Flat battery, or bad connection. Probably a main one, either on battery, solenoid or earth lead. Charge up battery and check it is holding charge (if possible). If it is OK, check all those heavy leads are clean and tight.
Old Jul 6, 2018 | 08:44 PM
fritz4000's Avatar
Default Thanks for the ideas
Thanks for the ideas. I will hopefully get a chance to check this out in the next couple of days and will post results.
Cody Moermond
Aug 17, 2016 10:40 PM
chinlucd
Aug 17, 2016 10:54 AM
1stimer87
Aug 9, 2016 02:29 PM
BradOwens
Jul 24, 2016 10:37 AM
connexion2005
Jul 20, 2016 09:24 AM
