baja 90cc atv sputters and bogs at 3/4 of the throttle
hi i have a baja 90cc atv which i bought from someone and whenever i try to do full throotle it bogs and spuuters it sounds horrible i changed the gas and the fuel filter and the plug is wet with gas can you please let me knw whats wrong with my atv i wanna get back to riding
on
When you say you have the same quad is it a *Baja* 90cc quad. They have owners manuals online with schematics (wiring diagrams) inside. Check out the following link:
Baja Motorsports | Owner's Manuals | Assembly Instructions
If you need further help just ask.
AllTruckRage,
on
Thankyou for the information but I need to know where the wire's go in the plastic plug in the cdi box there's two plug's one two prong and one six prong I need the two prong is two wire's but the six prong is five wire's in with an open slot I need to know where the wire's(w/colors) go corisponding to what slot???Thankyou again!!!
The classic color scheme for the above pins is:
Ignition Power: Black with Red Stripe
Kill Switch: Black with White Stripe
Ignition Trigger Pulse: Blue with White Stripe
Ignition Coil: Black with Yellow Stripe
Ground: Green
Many, but not all quads follow this color scheme.
If you really do have a 2 pin and 6 pin CDI can you post a picture of it? Also, what are the wire colors for all the wires going to the CDI?
i cleaned the carb twice and the plug came out black every time i put a new one in should i change the oil
