Help with crazy project
Old Nov 8, 2011 | 07:36 PM
jeremybrumbalow's Avatar
Default Help with crazy project
Hey guys, hoping someone knows a little more than me about this. I have a taotao ata125, which I disassembled, and I am currently turning it into a lawn mower. I know, sounds strange. But i'll post pics when I get done. My question is what is required to make the motor run. Like if im gonna run it on a bench. I figured it would just be the 2 coil wires need to be hooked up to the wires coming out of the side case? Any ideas?
Old Nov 9, 2011 | 12:26 AM
LynnEdwards's Avatar
Electrical Expert
Not hardly.
You've left out the CDI and all of its associated wiring (power, trigger, kill switch, and output to the ignition coil).
Wiring up all this stuff is *absolutely required* and a major endeavor. What happened to all the original wiring and parts?
Old Nov 9, 2011 | 06:28 AM
Originally Posted by LynnEdwards
Not hardly.
I think I have most of it. I purchased it from a guy who hacked up most of it. But Im pretty sure I do have the cdi and probably the harness for it. I wish someone had a wiring diagram for these little boogers...lol. So just to clarify, the coil comes off into the cdi, then the cdi runs down into the side cover for triggers and such.
Old Nov 9, 2011 | 07:28 AM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
Welcome to the forum jeremybrumbalow!
A lawn mower? Why? most folks want a reliable lawn mower..
Hope my sarcasm came thru in that.
now that Im past that..
A riding mower or a push mower?
Old Nov 10, 2011 | 12:07 AM
Electrical Expert
I don't have a wiring diagram for your specific quad, but there are lots of different wiring diagrams out there that will apply to this section or that section. You do some measuring on one section at a time (ignition, charging, kill switch section) then compare to existing diagrams and start to make an amalgam out of them.
CDI's have a lot of electronics inside (all very necessary). Basically they take power from some source (moderately high voltage AC from the stator, or DC voltage from the battery) and make an internal 100 to 300 volt internal DC supply. This supply is used to charge up a capacitor. At the proper time a small trigger signal from a small pickup coil in the stator fires the CDI which dumps the several hundred volt DC charge on the internal capacitor onto the ignition coil primary. These two form a high frequency resonant circuit which rings back and forth at 30 KHz or so. The ignition coil secondary winding (stepped up in voltage by a factor of 100 or so) is also resonant at the same frequency and generates the spark that ignites the fuel.
There is also the kill switch input to the CDI that disables the moderately high voltage supply that charges up the CDI capacitor. Without the high voltage charge the spark stops and the engine stops too.
All of these have to work to get spark...
Specta
Family ATVing Photos
Dec 7, 2018 08:22 PM
badgerboy1
Sep 26, 2017 06:11 PM
franklyme
Oct 21, 2016 07:18 PM
Mar 22, 2016 09:55 AM
mywifesquad
8
Sep 21, 2015 08:20 AM
