"HOW TO" 07 KFX90 CDI IN A 07 KFX50!!!
Old Dec 26, 2012 | 08:29 AM
LT80's Avatar
LT80 Expert
It's a 5 year old thread......................
Old Jan 4, 2013 | 08:48 PM
kenerly's Avatar
Originally Posted by LynnEdwards
The link shows a Gy6 engine performance CDI, but nowhere could I find a spec that says it is DC powered. I suspect this is AC powered (much more common with performance CDIs). If it is AC powered is absolutely will not work is a DC powered ignition system. If you plug it into a DC powered ignition system it will likely be instantly ruined.
Maybe you know more about the CDI in the link than is specified. Do you know that it is DC powered? I wonder why MotoPartsMax didn't specify this critical parameter.
Turned out to be a AC powered CDI.
I need to find a aftermarket DC CDI any ideas? The numbers on the original CDI is 30400-PVA1-900
Thanks
Old Jan 5, 2013 | 12:57 AM
LynnEdwards's Avatar
Electrical Expert
Search for "DC Casoli Performance CDIs".
AC powered ones are usually blue, while DC powered ones are usually gold.
I have no experience with these, so search diligently, and review all the the search input before buying .
Old Jan 18, 2013 | 11:47 AM
kenerly's Avatar
I got a CDI from ooRacing.
OORacing - performance monkey bike, pit bike, madass, zoomer, dirt bike components - CDI 4 pin D/C no limiter 14000 (Powered by CubeCart)
Wired it in, Runs great and starts everytime.
Old Jan 19, 2013 | 12:18 AM
  #15
Electrical Expert
I'm glad you got it working .
Thanks for reporting back...
Old Dec 20, 2020 | 10:05 PM
  #16
connexion2005's Avatar
Hey guys,
I know this thread is old but wanted to chime in and share that this absolutely works properly on the 2008 KFX 50 when using the different pinout on the CDI. I installed this model:
D111-HYCDI
Which is a Chinese CDI on our 08 KFX 50 and did the re-pinning mentioned above and it worked perfectly. In addition to repairing the quad, it's actually way more throttle responsive and does indeed seem to rev higher than the stock unit.
RedRancher
Oct 15, 2020 01:45 PM
Ramman1
Jun 16, 2016 09:07 PM
Captjay
Jul 23, 2015 12:33 PM
ghost civic
Jul 19, 2015 10:13 AM
Desimation2k8
Jul 17, 2015 12:37 AM
